Введение
Internal prerequisite
Выберете то, что вам нужно
Use a heat gun to gently heat the front panel to the right of the home button.
When prying up the glass take great care near the lock, mute and volume. The ribbon cable is fragile and is often glued to the digitizer. It will tear easily when the glass is pried up. Working from the lock button downward and staying flush with the underside of the glass will give you the best chance of not tearing the ribbon cable.
Once the area of the front panel to the right of the home button has been heated adequately, it should be easy to insert a plastic opening tool between the outer plastic bezel and the front panel right next to the home button.
Use your plastic opening tool to gently create a small gap between the front panel and the outer bezel to the right of the home button.
Insert a guitar pick into the small gap created by the plastic opening tool.
Heat up the area of the front bezel to the right of the home button along the bottom edge and make your way closer to the bottom right corner of the iPad.
Slide the first guitar pick toward the bottom right corner of the iPad and insert another guitar pick to maintain the gap between the front panel and the iPad next to the home button.
Use your heat gun to heat the edge of the front panel near the bottom right corner of the iPad.
Gently slide a guitar pick around the edge of the bottom right corner of the front panel, being careful not to force it and reheating the panel if necessary.
Continue heating the outer edge of the front panel and using guitar picks to separate/space the front panel from the rear panel.
Insert two guitar picks as placeholders on each side of the iPad.
When separating the front panel from the bottom left corner of the iPad 2, be careful not to rip the digitizer cable (highlighted in red in the first picture). It is extremely thin and easy to tear.
Slightly lift the front panel near the dock connector to separate it from the foam adhesive securing it to the LCD.
Use a guitar pick to help cut the foam adhesive securing the perimeter of the LCD to the front panel.
Carefully rotate the front panel away from the iPad, being sure that no adhesive is still attaching the two components.
2 участников успешно повторили данное руководство.
