Введение
Internal Prereq.
Выберете то, что вам нужно
Use the flat end of a plastic opening tool to flip up the retaining flap on the headphone jack and front-facing camera ribbon cable ZIF socket.
Run a plastic opening tool underneath the headphone jack and front-facing camera cable to free it from the adhesive attaching the cable to the rear panel.
Pull the headphone jack and front-facing camera ribbon cable straight out of its socket on the logic board.
Remove the two 2.9 mm Phillips screws securing the headphone jack to the rear panel.
Use the edge of a plastic opening tool to peel the tape and the adhesive securing the headphone jack & front camera cables to the rear panel.
Lift the headphone jack & front camera cables slightly to access the microphone connector.
Use the edge of a plastic opening tool to separate the microphone connector from its socket on the headphone jack & front camera cables.
Peel the front camera off the foam adhesive securing it to the rear panel.
Remove the headphone jack & front camera assembly from the iPad.
Use the edge of a plastic opening tool to disconnect the front camera cable from the headphone jack cable.
