Введение
Preq for removing the front panel. Specific to the iPad 3, also involves moving the LCD over.
Выберете то, что вам нужно
Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
Rotate the LCD along its left edge and lay it down on top of the front panel.
Еще один человек закончил это руководство.
What is the diameter/pitch of these screws in case someone (myself) loses them?
john Scrivener - Ответить
At this step, since I was replacing the glass and the digitizer anyway, I simply cut the digitizer cable and set aside the largest piece of glass. Since the shattered section was over most of the digitizer cable, this made working with the remaining glass shards much easier.
medhatmactech - Ответить
