iPad 3G Headphone Jack/Microphone Assembly Replacement
Выберете то, что вам нужно
  1. iPad 3G Headphone Jack/Microphone Assembly Replacement, Display Assembly: шаг 1, изображение 1 из 3 iPad 3G Headphone Jack/Microphone Assembly Replacement, Display Assembly: шаг 1, изображение 2 из 3 iPad 3G Headphone Jack/Microphone Assembly Replacement, Display Assembly: шаг 1, изображение 3 из 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 2, изображение 1 из 2 iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 2, изображение 2 из 2
    • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
    • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
  3. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 3, изображение 1 из 2 iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 3, изображение 2 из 2
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    • Pry the display assembly away from the rear panel.
  4. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 4, изображение 1 из 2 iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 4, изображение 2 из 2
    • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
    • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
  5. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 5, изображение 1 из 1
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not excessively lift the display assembly off the rest of the iPad, as a fragile antenna cable with very little slack still connects the two components.
  6. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 6, изображение 1 из 1
    • Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
  7. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 7, изображение 1 из 1
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
  8. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 8, изображение 1 из 3 iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 8, изображение 2 из 3 iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 8, изображение 3 из 3
    • Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
  9. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 9, изображение 1 из 1
    • Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  10. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 10, изображение 1 из 2 iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 10, изображение 2 из 2
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
  11. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 11, изображение 1 из 1
    • Remove the display assembly from the rear panel assembly.
  12. iPad 3G Headphone Jack/Microphone Assembly Replacement, Headphone Jack/Microphone Assembly: шаг 12, изображение 1 из 1
    • Use the edge of an iPod opening tool or your fingernail to flip up the ZIF cable retaining flap on the headphone jack socket.
    • Be sure you pry up on the cable retaining flap, not the socket itself.
  13. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 13, изображение 1 из 1
    • Carefully pull the headphone jack cable out of its socket on the logic board.
  14. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 14, изображение 1 из 1
    • Remove the two 2.8 mm T5 Torx screws securing the headphone jack to the rear case.
  15. iPad 3G Headphone Jack/Microphone Assembly Replacement: шаг 15, изображение 1 из 1
    • Remove the headphone jack from the rear case.
    • Make sure you transfer the rubber sound channel from your old microphone to the new microphone.
    • Before reinstalling the screws, be sure the headphone jack is properly seated in the headphone jack hole cut into the top edge of the rear case.
Заключение
3 участников успешно повторили данное руководство.
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 14,851
