Введение
Use this guide to replace your iPad 3G's logic board.
Инструменты
Запчасти
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
Rotate the spudger away from you to release the tabs along the top edge of the display.
Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
Pry the display assembly away from the rear panel.
Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
Digitizer
Ambient Light Sensor
Display Data Cable
Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
Pull the digitizer ribbon cables straight out of their sockets.
Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
Pull the cable connector away from its socket.
Use the edge of an iPod opening tool to carefully pry the remaining antenna connector up off the communications board.
De-route the control button cable along the top edge of the communications board.
Pull the communications cable upward to lift its connector up and out of the socket on the logic board.
Remove the single T5 Torx screw securing the communications board to the rear case.
Carefully peel back the rubber EMI shield covering the GPS antenna socket.
Use the edge of an iPod opening tool to flip up the GPS ribbon cable retaining flap attached to the GPS cable's socket on the logic board.
Use the edge of an iPod opening tool to pry up the retaining flap on the headphone jack/microphone socket.
Pull the headphone jack/microphone ribbon cable out of its socket.
Use an iPod opening tool to pry the SIM board connector up off its socket on the logic board.
Fold the SIM cable toward the bottom of the iPad to access the speaker connector.
Use the edge of an iPod opening tool to pry the speaker connector up and out of its socket on the logic board.
Remove the following screws securing the logic board to the rear panel assembly.
Two 4.56 mm T5 Torx screws.
Two 3.76 mm T5 Torx screws.
Use the edge of an iPod opening tool to carefully pry the dock cable connector straight up off the logic board.
10 участников успешно повторили данное руководство.
Один комментарий
Did this and everything worked great, but I forgot to re-attach the 3G antenna so I went back in to do that, closed it back up again and now my wifi isn't working. Any thoughts on what I likely messed up?
The first repair didn't require a software/firmware restore, but the second one did. I've restored twice now and reset network settings... all the suggestions Apple makes for troubleshooting a software issue, so I do think I messed something up inside. wobble man 3d
