Введение
Use this guide to replace a set of blown-out speakers.
Выберете то, что вам нужно
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
Rotate the spudger away from you to release the tabs along the top edge of the display.
Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
Pry the display assembly away from the rear panel.
Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
Digitizer
Ambient Light Sensor
Display Data Cable
Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
Pull the digitizer ribbon cables straight out of their sockets.
Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
Pull the cable connector away from its socket.
Remove the two 4.56 mm T5 Torx screws securing the dock connector cable to the main board.
Remove the single 2.84 mm T5 Torx screw connecting the dock connector cable to the rear case assembly.
Remove the two 2.84 mm T5 Torx screws securing the dock connector cable to the rear panel assembly.
Carefully remove the plastic cover over the WiFi/Bluetooth board and dock connector cable using an iPod opening tool.
Pry the Wi-Fi and Bluetooth antennas up off their respective sockets on the Wi-Fi/Bluetooth board.
Use the edge of an iPod opening tool to pry the SIM board connector up off it socket on the logic board.
Fold the SIM cable back for clearance to access the speaker connector.
Use the edge of an iPod opening tool to disconnect the speaker connector from the logic board.
Remove the two 2.84 mm T5 Torx screws securing the speaker assembly to the rear panel assembly.
Deroute the speaker cable connector from under the black sticker attached to the left side of the rear panel assembly.
Lift the speaker assembly and push it forward until the ports clear the bottom side of the rear panel assembly.
7 участников успешно повторили данное руководство.
