Введение
Use this guide to install adhesive strips on a replacement front panel.
Only for use with NEW front panel assemblies.
Выберете то, что вам нужно
Carefully peel off the first trapezoidal adhesive strip with a pair of tweezers.
Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
Lift and peel the clear backing up off the adhesive strip, revealing the black adhesive strip.
In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
Do not peel the clear backing off the strips just yet.
Place the bridge shaped adhesive strip between the top edge of the inner frame of the front panel and the camera mounting bracket.
Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Place the elongated C shaped adhesive strip on the right side of the front panel.
Place the straight, medium length adhesive strip on the bottom right side of the front panel, underneath the home button ribbon cable.
Place the tabbed rectangular adhesive strip on the bottom right side of the front panel.
Place the long L-shaped adhesive strip on the bottom left corner of the front panel.
Place the short rectangular shaped adhesive strip on the top left side of the front panel.
Place the last, short L-shaped adhesive strip on the top left corner of the front panel.
Use a pair of tweezers to peel the clear backing up off the adhesive strip directly underneath the home button ribbon cable.
Lay the home button ribbon cable down on the adhesive strip and smooth the cable down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Use a dry microfiber cloth to clean the LCD and inside of the front panel glass. You may want to use canned air or an air compressor to blow away and dust.
Use a pair of tweezers to peel the clear backing up off each adhesive strip.
Just anted to remind everyone to connect all your cables BEFORE sticking the screen down!!
…before attaching the LCD, in fact.
To go a step further in caution, leave the backing on the adhesive strips, attach all the cables (and replace the tape over them if you like), making sure all of the motherboard screws are in place. Then lay the LCD on top (without screwing it down), lay the glass on top of that, and TEST. Make sure you have full LCD and digitizer function. If not, do a hard reset and test again. If still not, dismantle everything and re-check the cables—they should be fully inserted (usually the white line should not show at all), with their latches down and no sharp crimps. It’s surprising how small a change in digitizer insertion can make a black screen suddenly function just fine.
You're finished.
You're finished.
33 участников успешно повторили данное руководство.
Один комментарий
Conclusion:
“To reassemble your device, follow these instructions in reverse order. “
Something goes wrong here…
