Введение
Use this guide to replace the cable with the volume control buttons in an iPad Air 2 Wi-Fi.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
Выберете то, что вам нужно
Heat the iOpener for thirty seconds.
Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
As you follow the directions, take special care to avoid prying in the following areas:
Home Button
Front Facing Camera
Main Camera
Инструмент, используемый на этом этапе:Clampy - Anti-Clamp$24.95
Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Place a suction cup over the iPad's front-facing camera and press down to create a seal.
Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
Slide the pick along the edge of the display, towards the headphone jack.
If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
Slide the left-hand opening pick down the edge of the display until you reach the corner.
Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
Twist the remaining pick by the front-facing camera to separate the top edge of the display assembly from the rear case.
Continue lifting the display assembly from the front-facing camera side.
Pull the display slightly away from the bottom edge to completely separate it from the rear case.
Keep lifting until the display assembly is roughly perpendicular to the body of the iPad.
Remove the single 1.8 mm Phillips screw securing the battery terminals to their contacts on the logic board.
Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
Alternatively, make a battery blocker using a playing card and slide it underneath the logic board connector to disconnect the battery.
Remove the three 1.3mm Phillips screws from the display cable bracket.
Remove the bracket.
Disconnect the two remaining digitizer cables underneath the display data cable.
Remove the following four Phillips screws securing the upper component cable bracket to the tablet.
Two 1.6 mm
Two 1.3 mm
Slide the upper component cable bracket out from under the protective flaps and remove it from the iPad.
Use the flat end of a spudger to disconnect the iSight camera from its socket on the logic board.
Remove the iSight camera.
Remove the 1.2 mm Phillips screw from the bracket covering the volume button cable connector.
Use the flat end of a spudger to pry up the volume button cable connector from its socket.
Slide an opening pick underneath the volume button cable to break up the adhesive attaching it to the rear case.
Using a spudger or your finger, press in on the volume buttons to pop out the button component board.
Slide an opening pick underneath the microphone on the ribbon cable.
Pry the microphone up to release it from its adhesive.
Gently insert a metal probe between the volume button cable and the plastic assembly piece.
Slowly break the adhesive by carefully moving the pick underneath the volume button cable.
Repeat the procedure from the previous step for the second button.
Gently pull the volume button assembly cable near the microphone to separate the last piece of adhesive holding it in place.
3 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
The volume on my IPad Air 2 was muting sporadically on its own. Replacing the volume cable fixed the problem. Great tutorial.
