Введение
Use this guide to replace the pair of Wi-Fi antennas in an iPad Air 2 Wi-Fi.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
  1. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    which temperature must be used for heating? Thx
    fbarletta - Ответить
    I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
    By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
    Fredrik -
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - Ответить
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - Ответить
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - Ответить
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - Ответить
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - Ответить
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - Ответить
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - Ответить
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - Ответить
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - Ответить
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - Ответить
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - Ответить
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - Ответить
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - Ответить
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - Ответить
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - Ответить
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - Ответить
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - Ответить
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - Ответить
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - Ответить
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - Ответить
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - Ответить
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - Ответить
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - Ответить
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - Ответить
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - Ответить
  2. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - Ответить
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - Ответить
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - Ответить
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - Ответить
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - Ответить
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - Ответить
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - Ответить
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - Ответить
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - Ответить
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - Ответить
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - Ответить
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - Ответить
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - Ответить
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - Ответить
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - Ответить
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - Ответить
  3. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - Ответить
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - Ответить
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - Ответить
    This thing melts when placed up side down in the microwave…
    Mark - Ответить
  4. If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    Why does it says in red letter to be sure not to damage the LCD screen? I thought the whole point of this guide is to replace a broken screen and the new screen comes with a new LCD since apparently they cannot be separated
    Stranger Danger - Ответить
    Because some people are opening the ipad to replace the battery! Like me~
    stephenwithph - Ответить
    The picture is a picture of an ipad 4 lol
    iCare Electronic Repair - Ответить
    The opening procedure is the same on many iPad models, so some photos are reused for all models.
    Daniele Carminati -
  5. The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
    • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
    Yeah, this part took longer than written. Over 30 minutes and had to reheat the iOpenner since it got cool enough to only feel warm.
    Christopher Lowder - Ответить
    So true, the adhesive is really strong.
    Benjamin Black -
    I would recommend using a hair dryer on high instead. Heat a certain area 60 seconds at a time and keep the hair dyer moving at a slow but constant speed.
    Alexander Chrisman - Ответить
    Hi!
    Is the quality of the iOpener so different, that for some people this guide works. but for most people including me, this 30 sec do not hotten the iOpener enough..
    Couldn't anybody do a new guideline with proper info, how many sec on which watt, etc. Pretty please!
    BUT, with that said, I would like thank You people on ifixit.com, for make all this tools. I f. love it! But plz make a new guide for at least iPad Air 2, screen replacement!
    Big love from Sweden and me Magni =) <3
    Magnifika Mole - Ответить
    Hello Magni!
    Microwave power can be vary, so you may need to microwave your iOpener longer in order to get it hot enough. The iOpener should be hot to the touch, about 80-100°C.
    Arthur Shi -
    Why do these instructions say to heat the top of the iPad for 2 minutes, but then prior open the bottom? The instruction below seem to indicate heating the side that you are about to pry open.
    mpulliam - Ответить
    I saw in some “How To”videos, the repair shop had expensive heating pads to assist in screen removal. If I ever find myself making a similar repair to an iPad of iPhone, I’m going to try using a heating pad I have for my back. Set it to high and let the iPad/iPhone set on it screen down for 15 minutes or so. Should do the trick.
    Charles Meitin - Ответить
    결국 히팅건을 사용했습니다. Bosch GHG 500-2 패드 알루미늄이 뜨거워질 때까지 가볍게 가열하십시오. 손가락으로 만지면 견딜 수 없을 정도로 뜨거워질 때까지 천천히 가열했습니다. iopener는 시간이 많이 걸리고 성공하지 못했습니다.
    jinwoo KIM - Ответить
  6. While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step. As you follow the directions, take special care to avoid prying in the following areas: Home Button
    • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
    you should be careful with the screen connector on the bottom right when opening
    Elyazee Eble Altenawe - Ответить
  7. Place a suction cup over the iPad's front-facing camera and press down to create a seal. To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    This is the trickiest and scariest part of the procedure. (read all of the comments in Steps 1 and 2 and at the end of the guide). The iOpener also did not work for me - it simply would not soften the glue enough. I used a blowdryer. Have lots of patience and be gentle! I did not pull up on the suction cup very much. I softened the glue enough that I could get my fingernail under the glass, then I was able to wedge the pick in beside it. The rest of the screen removal went easy with the blowdryer and blue picks.
    Nancy Hansen - Ответить
    It helps to know that the adhesive is v narrow (2-3 mm) tapes, not great globs of bitumen. Once the seal is broken, you’ve won. Also, the shiny bezel is part of the metal body, not the screen, so get your widget between the glass and the bezel. And be patient. Even with a heat gun and IR thermometer it still took me 30 mins to get the screen off.
    The screen glass can only be pulled up a fraction of a millimetre, just enough to insert the mere tip of an opening pick.
    The glue then gives way very slowly. Give it time to release before moving the pick slowly further in. If you pull the pick out without wedging the gap open with another pick the glue will re bind and you are back where you started.
    I used a very cheap Aldi laser thermometer to check temperatures. The glue seems to loosen at 41C+, although the heat takes time to penetrate.
    David Kennedy - Ответить
    When I purchased a new replacement battery, it came with a suction cup. That cheap cup wasn’t able to hold on the screen. luckily I had a set of heavy duty suction cups when I made a repair on my iMac. I recommend investing in the heavy duty cups.
    Heavy-Duty Suction Cups (Pair)
    These provide an excellent vacuum seal and leverage to lift the screen. Be careful and make sure you soften up the adhesive or you will crack the screen.
  8. Firmly pull up on the suction cup to to create a small gap between the front panel and the rear case. Do not pull too hard or you may shatter the glass. Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
    • Firmly pull up on the suction cup to to create a small gap between the front panel and the rear case.
    • Do not pull too hard or you may shatter the glass.
    • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
    Even using a heat gun in an effort to soften the remarkably tenacious adhesive, I found it impossible to use the suction cup to lift the edge of the screen sufficiently high to insert a pick. I ended up using an exacto knife and a single-edge razor blade to make the initial opening, after which I was able to insert and use picks per the instructions.
    James Steffy - Ответить
  9. Slide the pick along the edge of the display, towards the headphone jack. If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat. Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
    • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
    • Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch (6 mm) into the iPad.
    I think I accidently slid my tool into the fused lcd and front panel and now the entire screen is doing weird lines and different colors and just is not natural its not even usable. I was gonna replace the battery because the batter was popping the entire front panel and lcd off of the base of the device and then when i was openingit up the rest of the way I slipped and it hit something and now its all glitchy. what should i do?? is it even worth fixing anymore? it;s too old for apple care and I already voided the warranty and displays are expensive what should I do? email me @ andrew.heidorn1@gmail.com thanks :)
    Andrew Heidorn - Ответить
    “a quarter of an inch” might be OK for the US/UK… what about pretty much the rest of the world using the metric system? When giving measurements, please always include them also in mm/cm
    Denis Hay - Ответить
    A quick google search will give you the answer
    Stranger Danger -
    Metric is for engineers. Last place on earth to use inches is US car industry. NASA uses metric. You know it makes sense.
    Peter Goodall - Ответить
    I shattered the glass on my iPad during this step.
    To melt the adhesive, you have to heat the glass A LOT, to at least 80°C. I was using a portable infrared thermometer while doing this. Heating the iOpener in my microwave for 60 seconds only raised its temperature to about 90°C, and leaving it on the glass for a few minutes didn’t raise the temperature of the glass to more than about 40°C. I switched to a hair dryer and heated the glass to about 70°C, which was barely enough to be able to insert one pick. As soon as I tried to slide it across, the glass broke.
    I recommend having a reliable way to measure the temperature, and finding something that can heat more effectively than the iOpener. Also take caution to heat all along the top, not just the point where you’re inserting the pick. In theory the iOpener is designed for this, but it doesn’t get hot enough.
    I wish the iOpener came with a specific heat rating. It has many warnings against overheating it but it’s not clear exactly how much is too much.
    Daniel Corks - Ответить
    6mm is far too much at the side. There is only 4mm from edge of glass to the display unit . I guess I damages my display because the pledge had gone between glass and display.
    tobiasscholand - Ответить
    The picks should have a 5mm indent on them so you can’t push them in to far, at least on one of the tips
    mpulliam - Ответить
    warning! The gap just below the home button is 2mm. Be very careful. It is the thinnest space!
  10. Insert a second opening pick by the front-facing camera. Insert a second opening pick by the front-facing camera.
    • Insert a second opening pick by the front-facing camera.
  11. Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button. Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button. Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
    • Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
  12. Insert a third pick by the front-facing camera. Insert a third pick by the front-facing camera.
    • Insert a third pick by the front-facing camera.
  13. Bring the right opening pick down and around the top right corner of the iPad. Bring the right opening pick down and around the top right corner of the iPad. Bring the right opening pick down and around the top right corner of the iPad.
    • Bring the right opening pick down and around the top right corner of the iPad.
  14. Bring the left opening pick around the top left corner of the tablet. Bring the left opening pick around the top left corner of the tablet. Bring the left opening pick around the top left corner of the tablet.
    • Bring the left opening pick around the top left corner of the tablet.
  15. Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
    • Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
  16. Slide the right opening pick roughly halfway down the display. Slide the right opening pick roughly halfway down the display. Slide the right opening pick roughly halfway down the display.
    • Slide the right opening pick roughly halfway down the display.
    take care not to insert more than 4mm!
  17. Reheat the iOpener and apply heat to the left side of the iPad.
    • Reheat the iOpener and apply heat to the left side of the iPad.
  18. Slide the left-hand opening pick about halfway down the edge of the display. Slide the left-hand opening pick about halfway down the edge of the display. Slide the left-hand opening pick about halfway down the edge of the display.
    • Slide the left-hand opening pick about halfway down the edge of the display.
  19. Slide the opposite opening pick down to the bottom right corner of the iPad. If necessary, reheat the adhesive on the right edge to loosen the display assembly. If necessary, reheat the adhesive on the right edge to loosen the display assembly.
    • Slide the opposite opening pick down to the bottom right corner of the iPad.
    • If necessary, reheat the adhesive on the right edge to loosen the display assembly.
    This is it. This was the step where I cracked the screen and ruined the device. Things had been going so well up to this point. Like many others I struggled with the iOpener, so I used a heat gun along with a temperature sensor and very carefully and slowly went back and forth along the edges keeping the temperature at exactly 200 degrees F. I got the pick in, went around the top corners, down the sides to the middle. But on this step where you finish sliding the pick to the bottom right corner, I got 3/4ths of the way down and CRACK. The glass shattered pretty badly in the corner, and there’s a crack running diagonally along the entire device. I put clear packing tape on top to keep it from cracking further, but sections of the screen are non-responsive. I can’t tell you how upset my 5 year old is going to be when he wakes up tomorrow and I have to tell him daddy wrecked his iPad. :( I believe strongly in the Right to Repair and this kit is fine. But GO SLOWLY, and BE CAREFUL.
    George Mann - Ответить
  20. Slide the left-hand opening pick down the edge of the display until you reach the corner. Slide the left-hand opening pick down the edge of the display until you reach the corner. Slide the left-hand opening pick down the edge of the display until you reach the corner.
    • Slide the left-hand opening pick down the edge of the display until you reach the corner.
    I made it one step farther than the person above me. Made it about 1 inch from the bottom left corner and the screen shattered. I probably let it cool too much as I think I was getting a little impatient by now. The kit is great though. I successfully removed the rest of the screen even after it broke with no damage to anything else. I continued on to replace the battery and bought a new LCD (This was a roughly $130 mistake). I stress, go slowly, heat often. Kit worked great otherwise.
    Joseph Eichinger - Ответить
  21. Use the iOpener to apply heat to the bottom edge of the iPad.
    • Use the iOpener to apply heat to the bottom edge of the iPad.
  22. Bring the right-hand opening pick around the bottom corner of the iPad. Bring the right-hand opening pick around the bottom corner of the iPad. Bring the right-hand opening pick around the bottom corner of the iPad.
    • Bring the right-hand opening pick around the bottom corner of the iPad.
  23. Repeat for the left-hand pick. Reheat and reapply the iOpener as needed. Always wait at least ten minutes before reheating the iOpener. Reheat and reapply the iOpener as needed. Always wait at least ten minutes before reheating the iOpener.
    • Repeat for the left-hand pick.
    • Reheat and reapply the iOpener as needed. Always wait at least ten minutes before reheating the iOpener.
  24. Remove the right-hand opening pick at the bottom of the iPad. Remove the right-hand opening pick at the bottom of the iPad.
    • Remove the right-hand opening pick at the bottom of the iPad.
    F…ing cracked the glass. This repair is a waste of time and money. The iOpener is b.s. You need to use a heat gun and/or a blow dryer. I had used the heat gun and a blow dryer to successfully separated the glass from the body until I reached the bottom. This is becuase I had left the heated iOpener on the bottom for at least 20 minutes. I used the blow dryer for the top and sides and it worked. When I turned the corner on the bottom, the glass shattered. The tip of pick was not in very far, maybe 2mm. Guess my only option now is a new iPad.
    mpulliam - Ответить
    same here, and I’m not using their $2 dinky microwave palm rest, I have a head gun and I’ve been heating this thing for 20 mintues side by side. Still cracked the class. Don’t attempt this, to do this successfully you should’ve had cracked 10 screens.
    Hussam Almuayad - Ответить
  25. Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad. Be very careful to not insert the pick more than a quarter inch (6 mm) into the display to avoid damaging the Home Button and display cables underneath. Be very careful to not insert the pick more than a quarter inch (6 mm) into the display to avoid damaging the Home Button and display cables underneath.
    • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
    • Be very careful to not insert the pick more than a quarter inch (6 mm) into the display to avoid damaging the Home Button and display cables underneath.
  26. Twist the remaining pick by the front-facing camera to separate the top edge of the display assembly from the rear case. Twist the remaining pick by the front-facing camera to separate the top edge of the display assembly from the rear case. Twist the remaining pick by the front-facing camera to separate the top edge of the display assembly from the rear case.
    • Twist the remaining pick by the front-facing camera to separate the top edge of the display assembly from the rear case.
  27. Continue lifting the display assembly from the front-facing camera side. Pull the display slightly away from the bottom edge to completely separate it from the rear case. Keep lifting until the display assembly is roughly perpendicular to the body of the iPad.
    • Continue lifting the display assembly from the front-facing camera side.
    • Pull the display slightly away from the bottom edge to completely separate it from the rear case.
    • Keep lifting until the display assembly is roughly perpendicular to the body of the iPad.
    • Do not attempt to remove the display yet—it is still attached to the rear case by three delicate ribbon cables.
  28. Remove the single 1.8 mm Phillips screw securing the battery terminals to their contacts on the logic board.
    • Remove the single 1.8 mm Phillips screw securing the battery terminals to their contacts on the logic board.
    Be very careful when replacing the screws not to lose them. They are micro small. I would even think about ordering a couple extra of each size just in case.
    David Christoff - Ответить
    I have damge this battery terminals to their contacts on the logic board when I remove the battery. So how to fix this? Can buy that hardware to make replacement? Urgent! Need Help!
    jackwong.123 - Ответить
    Hi jackwong,
    If you are talking about the small springs that contact the battery, there is no easy way to replace them. You can try removing the board, applying a lump of solder on the contact with the broken spring, and see if that will be sufficient to connect to the battery contact when the board is screwed down.
    Arthur Shi -
    If the LTE version being worked on, ensure the sim tray is removed before attempting to isolate the battery.
    Brendon Gould - Ответить
  29. To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery. Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board.
    • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board.
    • Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
    Where am I supposed to get this part? I got the ifixit pro toolkit and didn't get this isolation pick
    Raid One - Ответить
    Since the battery blocker is a specialized tool used only for iPad repairs, we do not include it in the toolkit. You can purchase one here, or you can make one yourself by cutting a notch out of an opening pick.
    Arthur Shi -
    Can’t you just disconnect the battery?
    Pontus Sennerstam - Ответить
    So if this method is outdated, what is the current method to disconnecting the battery?
    Orochi - Ответить
    Orochi: right?? Come on guys, don’t tell us the method is outdated and then not explain what the better method is
    Subtle Hyperbole - Ответить
    A couple points: 1) You have piqued my interest! I’m now looking for the new, improved way to isolate the battery before embarking on the repair. 2) I have an iPad Air 2 with LTE, the area on ifixit.com for the LTE variant of the model does not have all the procedures that this WIFI only variant page has.
    bentley - Ответить
    Hey bentley,
    If you find a way to safely isolate the battery without the risk of damaging the connector pins, keep us posted!
    Arthur Shi -
    I did not do this part and had no problems. Just don’t bridge any metal parts with the screwdriver. (at least I assume this is what would cause a short)
    Actually you can cause some shorts with your fingers too. You can skip this step, but you must bee very carefull going on.
    Daniele Carminati -
    Heat motherboard then use plastic stick or guitar pick to gently unstick motherboard enough to insert peace of paper where battery contacts are.
    Thank me later.
    Popka Durak - Ответить
    I took a business card and notched it like the shown pick. Just wide enough to fit and notched to clear the screw post. Worked like a champ.
    마더보드는 바닥판에 접착되어 있습니다. 이것은 배터리 접점에서 들어 올려져야(약간 구부러져야) 합니다. 사진을 자세히 보시면 터미널의 좌우 기판도 보입니다.
  30. Remove the three 1.3mm Phillips screws from the display cable bracket. Remove the bracket. Remove the bracket.
    • Remove the three 1.3mm Phillips screws from the display cable bracket.
    • Remove the bracket.
  31. Disconnect the display data connector from its socket on the logic board. Disconnect the display data connector from its socket on the logic board.
    • Disconnect the display data connector from its socket on the logic board.
  32. Disconnect the two remaining digitizer cables underneath the display data cable. Disconnect the two remaining digitizer cables underneath the display data cable. Disconnect the two remaining digitizer cables underneath the display data cable.
    • Disconnect the two remaining digitizer cables underneath the display data cable.
  33. Remove the front panel assembly from the rear case.
    • Remove the front panel assembly from the rear case.
    • If you plan to reuse your display assembly, you will need to replace the display adhesive. Follow our iPad Adhesive Guide to reapply your display adhesive and reseal your device.
    Note on my iPad Air there was a little plastic cover around the front facing camera. Take that off an put it to one side as you will need it later for reassembly.
    John McDonnell - Ответить
    At this stage I found you do not need to do most of the rest of this guide although it does come with a warning. The battery is tethered to a metal ring which is the base of the retention screw in step 29. After Step 33, you can separate out the batteries from its adhesive now with a blow dryer or the iOpener (step 56). You will then find the battery free but hooked onto the ring. Take the blue opening tool (see step 55 for which tool this is) and wedge it where the battery is to make a gap. You can then lift the battery contact from its hook. After removing the battery, insert the new one into the small gap created by the wedge. The caveat is that you are bending the logic board a bit with the wedge so use this technique at your discretion.
    Raza Toosy - Ответить
    Thanks a lot! For my Celluar version (A1567 Air 2 Wi-Fi + Cellular), I followed the instructions to step 45 to remove all cables and connectors around the battery. Then I also jumped to step 56. To remove the middle part of the battery, I used a longer tool, a ruler, in addition to the enclosed "Plastic Cards". The glued battery could be removed by using the iOpener several times. In the end, the battery was only hanging on the clamp.
    Only now I understood that the battery was hanging on an eyelet on the back. The lever with the "iPad Battery Isolation Pick" was not enough. Therefore I cut an additional credit card with a small slot. The clamping point slipped out of the eyelet. The clamping point of the new battery could be plugged in again immediately.
    Josef Emmer -
  34. Remove the following four Phillips screws securing the upper component cable bracket to the tablet. Two 1.6 mm Two 1.3 mm
    • Remove the following four Phillips screws securing the upper component cable bracket to the tablet.
    • Two 1.6 mm
    • Two 1.3 mm
    • Slide the upper component cable bracket out from under the protective flaps and remove it from the iPad.
    Reinstalling the upper component bracket was tricky for me. It is difficult to get the bracket in proper orientation to replace screws and under the flaps at the same time.
  35. Disconnect the antenna cables by gently prying them straight up from their sockets. Disconnect the antenna cables by gently prying them straight up from their sockets. Disconnect the antenna cables by gently prying them straight up from their sockets.
    • Disconnect the antenna cables by gently prying them straight up from their sockets.
  36. Firmly grasp the antenna cable and peel up the grounding tape attaching it to the motherboard. Upon reassembly, it is important to reattach the antenna cables to the motherboard with grounding tape properly adhered on the copper strip underneath. Upon reassembly, it is important to reattach the antenna cables to the motherboard with grounding tape properly adhered on the copper strip underneath.
    • Firmly grasp the antenna cable and peel up the grounding tape attaching it to the motherboard.
    • Upon reassembly, it is important to reattach the antenna cables to the motherboard with grounding tape properly adhered on the copper strip underneath.
  37. Remove the following four Phillips screws from the right antenna bracket: Three 1.4 mm screws
    • Remove the following four Phillips screws from the right antenna bracket:
    • Three 1.4 mm screws
    • One 1.5 mm screws
  38. Lift the right Wi-Fi antenna out of its housing and remove it. Lift the right Wi-Fi antenna out of its housing and remove it. Lift the right Wi-Fi antenna out of its housing and remove it.
    • Lift the right Wi-Fi antenna out of its housing and remove it.
    When extracting the antenna, be careful to not tear the foam attached to the bottom (not shown in the pictures).
    There is adhesive attaching the foam to the antenna housing.
    David Listwa - Ответить
  39. Grasp the antenna cable with tweezers and gently peel up the grounding tape. Be careful to not rip the soldered cable connection. Upon reassembly, it is important to reattach the antenna cable to the motherboard with grounding tape properly adhered on the copper strip underneath.
    • Grasp the antenna cable with tweezers and gently peel up the grounding tape.
    • Be careful to not rip the soldered cable connection.
    • Upon reassembly, it is important to reattach the antenna cable to the motherboard with grounding tape properly adhered on the copper strip underneath.
  40. Use the flat end of a spudger to pry up the FaceTime camera cable socket from its socket. Pry the cable up to  free it from the adhesive securing it  to the rear case. Fold the FaceTime camera cable up and out of the way.
    • Use the flat end of a spudger to pry up the FaceTime camera cable socket from its socket.
    • Pry the cable up to free it from the adhesive securing it to the rear case.
    • Fold the FaceTime camera cable up and out of the way.
  41. Use the flat end of a spudger to pry up the audio jack cable connector from its socket. Pry the cable up to  free it from the adhesive securing it  to the rear case. Fold the ribbon cable to the left, out of the way of the antenna cable.
    • Use the flat end of a spudger to pry up the audio jack cable connector from its socket.
    • Fold the ribbon cable to the left, out of the way of the antenna cable.
  42. Peel up the two remaining pieces of grounding tape attaching the left antenna to the rear case, as done in the previous steps. Upon reassembly, it is important to reattach the antenna cables to the motherboard at all four taped locations with grounding tape properly adhered on the copper strip underneath. Upon reassembly, it is important to reattach the antenna cables to the motherboard at all four taped locations with grounding tape properly adhered on the copper strip underneath.
    • Peel up the two remaining pieces of grounding tape attaching the left antenna to the rear case, as done in the previous steps.
    • Upon reassembly, it is important to reattach the antenna cables to the motherboard at all four taped locations with grounding tape properly adhered on the copper strip underneath.
  43. Remove the following four Phillips screws securing the left Wi-Fi antenna: Three 1.4 mm screws
    • Remove the following four Phillips screws securing the left Wi-Fi antenna:
    • One 1.5 mm screw
  44. Lift the left Wi-Fi antenna out of its housing and remove it. Lift the left Wi-Fi antenna out of its housing and remove it. Lift the left Wi-Fi antenna out of its housing and remove it.
    • Lift the left Wi-Fi antenna out of its housing and remove it.
  45. The Wi-Fi antennas are connected to a common ground via conductive tape. Replace the assembly as a single unit to avoid issues caused by improper grounding.
    • The Wi-Fi antennas are connected to a common ground via conductive tape. Replace the assembly as a single unit to avoid issues caused by improper grounding.
Заключение
6 участников успешно повторили данное руководство.
Scott Havard
Участник с: 27.06.2016
45 604 Репутация
Автор 33 руководств
Один комментарий
I installed as directed. Thanks for that. Easy to follow. But still no wifi?
Gunther Mal - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 38
За последние 30 дней: 160
За всё время: 10,574
