Введение
Prereq for removing logic board. Battery is out.
Выберете то, что вам нужно
Remove the following screws:
One 2.5 mm Phillips #00
Two 1.1 mm Phillips #00
One 1.2 mm Phillips #00
Use the flat end of a spudger to loosen the foam adhesive holding the antenna to the right speaker.
Почти готово!
Заключение
