Введение
Prereq only, does not remove antenna, battery is in.
Выберете то, что вам нужно
Remove the following screws securing the GPS antenna to the rear case:
One 2.5 mm Phillips #00
Two 1.1 mm Phillips #00
One 1.2 mm Phillips #00
Use the flat end of a spudger to loosen the foam adhesive holding the GPS antenna to the right speaker.
Gently de-route the antenna cable from the bottom right corner of the rear case.
Move the antenna out of the way of the right speaker.
