Введение
Prereq for removing the logic board. Battery has been removed.
Инструменты
Запчасти
Детали не указаны.
Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker.
Slide the tip of a spudger through the gap between the wide tape and the antenna cable, breaking the adhesive connecting the two.
Continue pulling the wide tape until it is no longer covering the antenna cable.
Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
Remove the following three screws securing the bottom left antenna to the rear case:
One 1.2 mm Phillips #00 screw.
One 1.1 mm Phillips #00 screw.
One 2.5 mm Phillips #00 screw.
Use the flat end of a spudger to loosen the foam adhesive securing the lower left antenna to the left speaker.
