Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prerequisite only guide. Shows how to swing open the Display Assembly for the iPad Pro 9.7"
Выберете то, что вам нужно
Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
Twist the top and bottom picks to separate the display assembly from the rear case.
Swing the display assembly towards the right of the case, using the right edge as a hinge.
As you move the display assembly, make sure that the display ribbon cable is not being stressed.
Continue swinging the display assembly until it lays flat next to the rear case.
