iPhone 11 Lightning Connector Assembly Replacement
Выберете то, что вам нужно
Видеоинструкции
Заключение
40 участников успешно повторили данное руководство.
Arty
Участник с: 10/27/19
24 481 Репутация
Автор 92 руководств
14 Комментариев
I would rather have a picture and written step by step, he doesn’t say some parts what is called
Dulce Vidal - Ответить
Me too. I would appreciate knowing the size and type of all screws and standoffs and where they go.
I most likely mixed up a few of them and now the screen stays black.
Kim Mace -
First, DISCONNECT the battery before ANY connections, and the battery should be the last thing you re-connect. And you DO NOT need to remove the logic board.
Gregg Stanley - Ответить
Just completed this repair. Wow it’s tricky but as echoed above, I would try and disconnect battery first although design of the iPhone 11 makes it very difficult to do this. Also, definitely don’t remove logic board and you don’t have to remove the battery either. Removing battery possibly makes it very slightly easier but if you take your time it’s not necessary. Good luck
richarddillon - Ответить
IS not there a problem with at chip on the charging flex, that causes warnings and or re-boots I have been reading about somewhere?I mean, fitting it is easy enough, but APPPPle keeps annoying customers trying to stop them going to independent shops or doing repairs themselves!
JoeBlog - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 38
За последние 7 дней: 263
За последние 30 дней: 1,332
За всё время: 53,950
