Введение
Use this guide to remove or replace the two screws securing the iPhone 11 display panel. These are the only screws on the exterior of the iPhone. They use a five-point design that is unique to Apple, requiring a specialty P2 pentalobe driver for removal.
Выберете то, что вам нужно
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
12 участников успешно повторили данное руководство.
the right screws wouldn’t come off
Yusef San Inocencio - Ответить
ok one came of but my right wont come of either!!!!
Aisa Jawara -
Hello guys, I still haven't found away to power off the iphone without using the screen. Cheers!
danielaguirre93 - Ответить
You can try this.
Quickly Press and release the volume up button.
then Quickly Press and release the volume down button.
then press and hold the power button and wait until it turns off.
worked for me :D
Benóný Egilson - Ответить
Where does one get replacement seals? Is this the same as the display assembly adhesive?
Brian Baker - Ответить
not of the screwdrivers i have seem to be able to turn the screws
Aisa Jawara - Ответить
