iPhone 11 Pentalobe Screws Replacement
Выберете то, что вам нужно
  1. iPhone 11 Pentalobe Screws Replacement, Remove the pentalobe screws: шаг 1, изображение 1 из 2 iPhone 11 Pentalobe Screws Replacement, Remove the pentalobe screws: шаг 1, изображение 2 из 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    the right screws wouldn’t come off
    Yusef San Inocencio - Ответить
    ok one came of but my right wont come of either!!!!
    Aisa Jawara -
    Hello guys, I still haven't found away to power off the iphone without using the screen. Cheers!
    danielaguirre93 - Ответить
    You can try this.
    Quickly Press and release the volume up button.
    then Quickly Press and release the volume down button.
    then press and hold the power button and wait until it turns off.
    worked for me :D
    Benóný Egilson - Ответить
    Where does one get replacement seals? Is this the same as the display assembly adhesive?
    Brian Baker - Ответить
    not of the screwdrivers i have seem to be able to turn the screws
    Aisa Jawara - Ответить
Заключение
12 участников успешно повторили данное руководство.
Jeff Suovanen
Участник с: 08/06/13
428 116 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
Один комментарий
I was putting in a SIM card on my new iPhone 11 and it bounced and I will not find it. Can you send me one or two and a tool to use bc it is so small?
Dah - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 14
За последние 7 дней: 150
За последние 30 дней: 690
За всё время: 24,667
