Введение
Use this guide to remove all components from the rear case of your iPhone 11 Pro. This guide will show you how to remove speaker, cables, taptic engine, battery, logic board, and button covers so you can replace a dented or bent cover.
Видео обзор
  1. iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: step 1, image 2 of 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Заключение
9 участников успешно повторили данное руководство.
Arty
Участник с: 27.10.2019
12 006 Репутация
Автор 71 руководств
Комментариев: 3
how much for housing iphone 11 pro ? Thank you
daddy - Ответить
If yo buy it from indonesia it only cost you arround $100-$200
izaz adityas -
I ordered a new charging port but it doesn’t seem to include a speaker element on the left side, and the charging connector module above the port. Can those be moved over from the old charging port?
lemonlev - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 82
За последние 30 дней: 424
За всё время: 13,069
