Введение
Use this guide to remove and replace the rear cameras in the iPhone 11. The rear camera assembly consists of one wide-angle module and one ultra-wide angle module. Both are replaced together, as a single unit.
Note: This guide instructs you to completely detach the display cables and remove the display assembly in order to better access the rear cameras—however, it's possible to remove and replace the rear cameras with the display cables still connected. Advanced readers may skip disconnecting the display in order to save time, as long as the display is properly supported and the display cables are not damaged.
  1. Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Power off your iPhone before beginning disassembly.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
  3. The next two steps demonstrate the iSclack, a handy tool that we recommend for anyone doing frequent repairs. If you aren't using the iSclack, skip down two steps for an alternate method. If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger iPhones like the iPhone 11.
    • The next two steps demonstrate the iSclack, a handy tool that we recommend for anyone doing frequent repairs. If you aren't using the iSclack, skip down two steps for an alternate method.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger iPhones like the iPhone 11.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Press both suction cups firmly into place.
    • If your display or back glass is badly cracked, covering it with a layer of clear packing tape may help the suction cups adhere. The iSclack also includes two pieces of tape for this purpose.
  4. Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone. Don't try to completely separate the screen; a small opening along the bottom edge is all you need. Insert an opening pick into the gap under the display on the lower edge of the iPhone.
    • Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone.
    • Don't try to completely separate the screen; a small opening along the bottom edge is all you need.
    • Insert an opening pick into the gap under the display on the lower edge of the iPhone.
    • Skip the next two steps.
  5. If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass. If your display is badly cracked, covering it with a layer of clear packing tape may help the suction cup to stick. Alternatively, you can use very sticky tape instead of the suction cup. Or if all else fails, you can superglue the suction cup to the broken screen.
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may help the suction cup to stick. Alternatively, you can use very sticky tape instead of the suction cup. Or if all else fails, you can superglue the suction cup to the broken screen.
  6. Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert an opening pick into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  7. Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place. Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components. Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components.
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert the opening pick too far into the iPhone, or you may cause damage to internal components.
  8. Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive. Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel. Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  9. The top edge of the display is secured with both glue and clips. Gently pull the right edge of the display down slightly (in the direction of the Lightning port). Insert your pick into the top-right corner of the phone.
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  10. Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick. Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Again, don't insert the pick more than a few millimeters—about the width of the display bezel—or you may damage the Face ID sensor array.
  11. Pull the small nub on the suction cup to detach it from the front panel.
    • Pull the small nub on the suction cup to detach it from the front panel.
    • If you used an iSclack and it's still affixed to the iPhone, remove it now.
  12. Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board. Prop the display up against something sturdy.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  13. To access the screws in the following step, tilt the display by slightly lifting its lower edge. Be careful not to strain or tear the display cables.
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  14. Remove the bracket.
    • Remove the bracket.
  15. Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board. Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  16. Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket. Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
  17. Remove the bracket.
  18. Use a spudger or a fingernail to disconnect the LCD panel cable connector. Disconnect the digitizer connector next to it. Disconnect the digitizer connector next to it.
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
  19. Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector. Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  20. Remove the display assembly.
  21. Remove the two Phillips screws securing the rear camera cover: One 1.4 mm screw
    • Remove the two Phillips screws securing the rear camera cover:
    • One 1.4 mm screw
    • One 1.3 mm screw
  22. Lift the camera cover from the edge closest to the battery, and remove it. To reinstall the camera cover, follow the images exactly in reverse: first, lower the outside edge until the two protruding tabs on the cover are slotted securely into the bracket on the outer edge of the camera module. Then, hinge the cover closed. The cover only lays flat after the two tabs are seated correctly.
    • Lift the camera cover from the edge closest to the battery, and remove it.
    • To reinstall the camera cover, follow the images exactly in reverse: first, lower the outside edge until the two protruding tabs on the cover are slotted securely into the bracket on the outer edge of the camera module. Then, hinge the cover closed.
    • The cover only lays flat after the two tabs are seated correctly.
  23. Use a spudger or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets. Use a spudger or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets. Use a spudger or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
    • Use a spudger or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
  24. Insert the point of a spudger at the bottom right corner of the camera, between the camera assembly and the iPhone's frame. Gently pry up to lever the camera out of the iPhone.
    • Insert the point of a spudger at the bottom right corner of the camera, between the camera assembly and the iPhone's frame.
    • Gently pry up to lever the camera out of the iPhone.
  25. Remove the rear-facing camera assembly.
    • Remove the rear-facing camera assembly.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Answers community for help.
12 участников успешно повторили данное руководство.
Jeff Suovanen
Участник с: 06.08.2013
354 869 Репутация
Автор 258 руководств
Команда
iFixit Участник iFixit
Community
137 членов
Автор 16 433 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 69
За последние 7 дней: 387
За последние 30 дней: 1,460
За всё время: 23,487
