Введение
This guide shows how to remove the two bottom Pentalobe screws on the iPhone 4.
Выберете то, что вам нужно
Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
432 участников успешно повторили данное руководство.
3 Комментариев
What do you do when you strip a screw
I also think I stripped one of the pentalobe screws,one came off the other was a problem from the start. How do you deal with a stripped pentalobe screw?
Hey there! Our Answers forum has a lot of great solutions to this problem! Check out these posts 3.6 mm Pentalobe screw is stripped, What to do when my iPhone pentalobe screws are stripped?, How can I remove a striped pentalobe screw? Good luck!
