Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Power off your iPhone before beginning disassembly.
Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the metal clip covering the antenna connector.
Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Remove the battery.
Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
Remove the two 1.8 mm Phillips screws securing the dock connector cable cover to the logic board.
Remove the metal dock connector cable cover.
Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
Remove the pressure contact.
Use the edge of a plastic opening tool to pry the Wi-Fi antenna cable up from its socket on the logic board.
De-route the Wi-Fi antenna cable out from under the metal fingers attached to the logic board.
Remove the two 2.4 mm Phillips screws securing the speaker enclosure assembly to the outer case.
Remove the small black spacer that was under the Phillips screw near the vibrator.
Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
Remove the speaker enclosure assembly.
Remove the two 1.6 mm Phillips screws securing the cellular antenna to the speaker enclosure.
Starting near the cellular antenna cable, use the edge of a plastic opening tool to peel the antenna off the speaker enclosure.
Continue peeling the cellular antenna off the speaker enclosure, being careful not to rip the gold bracket attached to one of its edges.
Remove the cellular antenna.
20 участников успешно повторили данное руководство.
