Введение
If you have a problem with charging, connecting with iTunes, don't hear you in a phone call, connecting with WiFi, ringing.
In this video manual we will show you how to change / replace the iPhone 4S USB Charging Port Dock Connector Flex Cable with Mic and inner Ringer / Loud Speaker & WiFi Antenna flex.
Выберете то, что вам нужно
Видео обзор
If present, remove the small strip of tape covering one of the dock connector screws.
Use a plastic opening tool to flip up the retaining flap on the home button ribbon cable ZIF socket.
Carefully pull the rubber microphone holder out of its tube in the bottom edge of the iPhone.
Remove the two 1.3 mm Phillips screws securing the dock connector to the case of the iPhone.
Use the edge of a plastic opening tool to peel the dock connector and its cable off the black plastic case of the iPhone.
Pry the dock connector away from its opening at the bottom of the iPhone.
Remove the dock connector.
19 участников успешно повторили данное руководство.
