Введение
Use this guide to replace the metal volume buttons.
Выберете то, что вам нужно
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
Remove the rear panel from the iPhone.
Remove the following screws securing the battery connector to the logic board:
One 1.7 mm Phillips screw
One 1.5 mm Phillips screw
Carefully push the pressure contact away from the battery connector until it slides free from its position.
Remove the pressure contact.
Use a plastic opening tool to gently pry up the battery connector from its socket on the logic board.
Place the tip of the tool between the loudspeaker enclosure and the metal cover of the connector, and lift the bottom edge of the connector first.
Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
Wait about one minute for the alcohol solution to weaken the adhesive.
Use the flat end of a plastic opening tool to gently lift the battery.
Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
Remove the battery.
Remove the three 1.5 mm Phillips screws securing the volume button bracket to the outer case.
Pull the volume bracket slightly away from the outer case.
Use a pair of tweezers to remove the volume buttons from the iPhone.
78 участников успешно повторили данное руководство.
7 Комментариев
I ordered this and it got delivered in 3 days internationally
I never opened and iPhone before , but it was an easy fix
Took me about 20 minutes.
All you need is
1- Home Tech Toolkit
2- Pentalobe Screwdriver
this way you save a lot instead of buying each tool alone
the guide was very decent and easy but could have provided better images for the "ground clip"
other than that it was easy fix , thank you ifixit
and I did NOT replace the 5-point screws with equivalent Phillips screws
Thanks for the great guide. Is it possible to buy the volume button shim (Apple part# 923-0072) as mentioned here: http://markshangout.com/blog/2013/8/22/i.... Mine is showing the same behavior. Thanks in advance!
when i removrd the volume brackets i saw that my problem has nothing to do with the volume buttens itself. on the volume bracket are 2 buttens wich are pushed by the outside volume buttons and on top of each inside button is a very small black thing wich is in my case missing at one button.
at step 9 you can see it at the plus side a little. anyone any iddea how to fix this?
I had this problem too! usually, you can find the little black circle stuck on one of the adhesive pads near the volume buttons and stick it back on using tweezers and a magnifying glass.
If you can't find it, you can cut a sticker so that it's about the same size as the little black dot, then reassemble as usual: )
I have an iPhone that vol + button isn't working on. It isn't clicking like the vol - button and seems to move more when I press on it. On the inside everything looks tight, could this missing sticker have something to do with it?
