Введение
Используйте это руководство, чтобы заменить разговорный динамик на iPhone 5.
  1. Если стекло дисплея разбито, то в процессе ремонта важно предотвратить его дальнейшее разрушение (которое, кстати, может повлечь за собой серьёзные травмы). Заклейте стекло клейкой лентой.
    • Если стекло дисплея разбито, то в процессе ремонта важно предотвратить его дальнейшее разрушение (которое, кстати, может повлечь за собой серьёзные травмы). Заклейте стекло клейкой лентой.
    • Наложите столько слоёв прозрачной ленты, сколько потребуется. Дисплей должен быть заклеен полностью.
      • Тем самым осколки в дальнейшем никуда не денутся, а структурная целостность — сохранится.
    • Чтобы уберечь глаза от случайного попадания осколков, пользуйтесь защитными очками.
    Having completed this repair using the rear camera part from Ifixit I have to comment that the camera is noticeably lower quality. Its not huge - You don't notice it looking at the photos scaled down to fit but viewing one for one there is significant detail lost. My staff member has an Iphone 5 bough at exactly the same time as mine so I was able to take a photo side by side on his and mine after my repair and when you view 1 for 1 pixel in product boxes on mine the text was just a colored blur where on his although you couldn't read the text it was more obviously text. Overall though its still better than having a camera that wouldn't focus at all and being that Apple seem to refuse to supply genuine spare parts (Which there has to be a low against??? - Imagine if a car manufacturer did that) its still good buying one from someone who gives good support. At the end of the day its a phone camera not an SLR and its still better than the older Iphone 4 camera.
    matt - Ответить
    The majority of product manufacturers are not required to provide parts, and apple will fix items under the various warranties it offers. Car manufacturers on the other hand are required to make parts available by law. It is part of the regulation of their industry. They get a lot of protection for their business model, but have some obligations too. It's why the EV1 was pulled, they didn't want to have to make the parts, and why there are so many Delorian parts.
    William Leeper -
    This is a great guide. However, I'm having a hard time popping the screen back into place. Everything works but I'm afraid of putting too much pressure least I crack it again. Any advice?
    amciotola - Ответить
    To avoid broken screens during reassembling:
    Put the hooks of the screen in the right place in the housing, then close it loose, don't press it. Turn your phone upside down with the screen on a very flat surface (e.g. table). Now press the housing on the screen -> no more risk for braking the screen because of inhomogeneous force applied on the glass!
    mondbewohner -
    I hope folks read this comment before proceeding to attempt a Sleep/Wake button repair on the iPhone 5! Apple has an iPhone 5 Sleep/Wake button replacement program, free, for iPhone 5 devices manufactured through March 2013. See program details at https://www.apple.com/support/iphone5-sl.... Don't do this yourself if you don't need to. It's a difficult repair.
    Mark Luscher - Ответить
    I was willing to add the following important remark on top of this guide but, strangely, it has been refused! Here it is:
    *Check if your Iphone 5 is eligible to the Apple special program for a free battery replacement (devices sold between September 2012 and January 2013, within a limited serial number range).
    * If not, watch the video and use this guide [video|https://www.youtube.com/watch?v=6ogE8USs...]
    And thus, as my Iphone 5 was eligible, I went to the Apple store of Le Louvre in Paris and the battery has been changed for free instead of 65 euros. Thanks to Mark!
    revher -
    Hi every one i drop my iphone5s 16gb
    I replace 10!new screen but cant back to live i see on the "logic board" where u conect the screen i se damage HOW CANT FIX THAT WHITOUT LOST MA DATA ??? Thaks for anny hellp!!!!!
    aliroberto01 - Ответить
  2. Перед тем, как разбирать iPhone, убедитесь, что он выключен и не подсоединен к зарядке.
    • Перед тем, как разбирать iPhone, убедитесь, что он выключен и не подсоединен к зарядке.
    • Открутите оба 3,6 мм Pentalobe-винта рядом с разъемом Lightning.
    I would recommend keeping multiple pieces of double-sided tape for each step that requires removing screws. Also perhaps label them, or take notes, so you know which piece of tape (and the screws attached to it) go with which step number. It's easy to confuse screws, especially if you go past these instructions to remove everything required to replace the ribbon cable that is necessary for the buttons.
    irwin fletcher - Ответить
    To avoid misplacing screws or other elements, printout the instructions, apply transparent tape onto the print wherever you have colored circles marking different screws. Then, as you start removing screws, tape each one on top of its image on the instructions. At the end, to reinstall everything, proceed from the end of the instructions, removing each taped screw from its image, to return it to its original position. I have done this with many iFixit repair instructions, never losing or misplacing any screw!
    bduault -
    Ordered and received the Phillips #00 Screwdriver ($5.95 · 50+ In stock). It is a tiny Philips screwdriver. The screws next to the lightning port have tiny star-shaped holes. I will have to find a different screwdriver.
    jacklingwood - Ответить
    Unfortunately, the kit I ordered that was to come with a suction cup didn't include one; thanks for quality control, ifixit. Tape doesn't work. Now what?
    btarver - Ответить
    I'm sorry to hear that. I have a suction cup being sent out today (Tue 3/11/14) and it will be there tomorrow for you.
    Scott Dingle -
    I've managed to replace the battery successfully in my iPhone5, but something went wrong with a friend's (battery status is stuck, sometimes the phone reboots for no reason).
    So, i decided to open it up again and reseat the ribbon cables in case they came loose.
    I can't open it now. The Pentalobe screwdriver is worn out! I can't open these screws no matter what. I don't know what to do now as I can't be sure I haven't worn out the actual screws themselves, too. Any ideas?
    Saltank - Ответить
    I seem to be having a similar situation. Attempting to open the phone again and either the pentalobe screws or the screwdriver itself is stripped. Any suggestion is welcome for removing the screws.
    Battery replacement went well and works great. But I must have a loose (hopefully not damaged) display ribbon.
    pwarkolla -
    Saltank, thanks to your comment I didn't overtighten those little screws! I would try to get a better quality driver from a local hardware store to see that helps, the one ifixit sent are not very good quality. If that doesn't work, you may have stripped the screws.
    SMSHAHKHAN -
    Wish I ordered a back case as well with my repair being so easy!
    Daniel Hatton - Ответить
    my phones screen displays the dead battery sign and the plug below it sign too, when your phones battery is dead. Bought a new battery and charged overnight...... any ideas?
    Steve Freed - Ответить
    Hi Steve! I'm experiencing the same issue. Were you able to fix it? Please let me know
    Brittany Hutchinson -
    Steve. Please contact me asap re: the issue on your phone. Thank you.
    Now here's an issue that would seem to apply to many users doing this repair: if the screen is nonfunctional, how do you power-off the device? When I dropped my iPhone, the screen went almost completely dark, midnight blue, actually. I can use the power button at the top of the phone to turn the display on and off, but I can't get the phone to power off. Seems the only way to do it is to wait until the battery is exhausted.
    dwhyink - Ответить
    Protip: take all the soda out of a case of pop and complete the repair in the empty cardboard tray. That way if you drop a screw it won't go flying off the table.
    John Penfold - Ответить
    Ok, at the end of the repair, I tried to use the new pentalobe screws that came with ifixit replacement battery but they did not seem to fit. So, reverted to the original pentalobe screws for the final step to close up the phone. Beside that, everything went smooth. I also skipped the steps about detaching the frontpanel (seems not necessary if only replacing the battery)
    Srikanth - Ответить
    Weirdly I had to use two different screw attachments to remove the pentalobe screws so possible they use different screw heads for each one sometimes.
    Sam Ashken - Ответить
    The “Pentalobe” screws require the STAR DRIVE driver, NOT a Phillips driver.
    Vard Nelson - Ответить
    • Следующие два слайда призваны показать принцип работы iSclack — прекрасного инструмента для вскрытия iPhone 5. Мы рекомендуем iSclack каждому, кто планирует совершить больше одной починки. Если вы не используете iSclack, сразу переходите к шагу 5.
    • Откройте «челюсти» с присосками, сведя ручки iSclack вместе.
    • Поместите iPhone между присосок, вложив его в пластиковый ограничитель.
      • Верхняя присоска должна оказаться чуть выше кнопки Home.
    • Сведите присоски вместе, разведя ручки. Крепко прижмите присоски к передней и задней панелям iPhone.
    The iSclack is a marvel. I've had it in my toolkit for a while but this was its first use. I recommend this tool.
    jlwilliams03 - Ответить
    • Удерживая iPhone, вновь сведите ручки iSclack вместе. Передняя панель выскочит из корпуса.
    • Угол раскрытия iSclack специально подобран , чтобы корпус и панель можно было отсоединить друг от друга, не повредив шлейф кнопки Home.
    • Отсоедините детали от присосок.
    • Сразу переходите к шагу 7.
    Step 4 is a bit dangerous, as the Display is pulled out very fast and (depending on the position, the suction cups are placed at) it could stress the cabels connecting display and mainboard. So, please, hold the phone with finger and thumb at the top, to avoid the display is pulled out to fast.
    Guido Dampf - Ответить
    I sure wish they did a better job showing in the video how hard it is to take of the front screen without the iSclack tool!
    CHRISMIYAMOTO - Ответить
    I had to position the suction cup _over_ the home button in order to get the screen far enough away from the frame to slide my trim tool in there. Putting it down above the home button just wasn't working at all...
    tparkinson - Ответить
    Was someone able to answer this question? I have the same issue
    Brittany Hutchinson - Ответить
    without this suction cup clamp thing, removing (and replacing) the screen was the hardest part of this job. Especially when the screen is cracked badly as the suction cup loses suction due to air leaking through the cracks. In this case, use tape over the screen to create a smooth surface. ***Also, the screens have rubber running along the side, so use a heat gun or hair dryer to make the rubber softer for removal of cracked screen and installation of replacement screen
    fakik0240 - Ответить
    • Закрепите присоску на экране как раз над кнопкой Home.
    • Убедитесь в том, что присоска полностью и прочно закреплена на стекле.
    • Если стекло разбито, аккуратно проклейте несколько полосок скотча. При закреплении присоски убедитесь, что выдавлены все воздушные пузырьки. Таким образом получится снять экран и предотвратить дальнейшее распространение трещин на стекле.
    I found it was easier to start opening from the top left of the display and working straight down towards the home button as there are no clips in this particular area. I realize there are cables on the right side right next to the area, however, this way requires less force as a starting point. Let me know what you think.
    boxerbc - Ответить
    I think that's not a good idea as the top of the display is held in place with plastic tabs.
    If you apply to much force they can break.
    Johnny - Ответить
    This part was the most frustrating part of the guide, granted I didn't do the whole thing. I was expecting to slip the plastic separator tool in-between the case and the display. This did not happen and I ate away at the tool in the process. For me after much pushing on the top edge of the case and pulling the screen away it released all of a sudden. I managed to make a dead stop at 90 degrees, but felt like I almost ripped off the ribbon cables(I didn't).
    maxturkewitz - Ответить
    No matter how hard I tried, I could not get the screen to separate far enough to where the pry tool could get it. Reading through some of the other comments, I followed 2 other people's advice to work the bottom left corner above the headphone input and then use a pushpin at the same time. (this is not recommended, but it worked!) I made a couple of hard to see marks in the corner but was finally able to get the screen off. I also did NOT take off the connectors to the screen and skipped the next few steps all the way down to step 14. Looks like a lot of people damaged their phones that disconnected the top screen.
    I'd recommend to use packaging tape to attach the upper edge of the display to the back of the phone so you won't rip off the ribbon cables if the display suddenly comes loose.
    Cupper Chopper - Ответить
    I took the suction cup off of an old navigation Tom Tom and it worked great!
    fijisomeday - Ответить
    My battery needed replacement because the battery had swollen and was warping the glass. Looking at it from the side it looks like gasket that was partly sticking to glass and partly to the case. This is actually part of the glass frame and you need to make sure to separate it from the case not the glass. I did it wrong and ended up removing the glass but there was a metal case covering the inside. I eventually got the rest of the top off but now I'll have replace it all because I can't find a good way to glue the glass to plastic.
    Wade Whitaker - Ответить
    I initially had trouble, but focusing on the area of the faceplate right above the headphone jack worked for me. There's a slight divot that allows you to slip in the prying tool earlier than in other places around the faceplate. Once I got the prying tool in there, I was able to pop out the bottom, and then continue up the sides.
    Stuart Nelson - Ответить
    IMPORTANT TO NOTE: The top of the screen is attached to delicate cables inside the phone! Pull up carefully and keep a hand on the top of the screen so it doesn't pop up.
    gobluethunder - Ответить
    My iPhone 5 only had a weak battery. Now it has a cracked glass panel. Suction cup is strong - so strong the glass breaks before the suction cup lets go. Apparently some of the tolerances in Apple's design occasionally add up to make a front panel assembly that refuses to let go. Phone not worth repairing at this point as it only cost $190 refurbished to begin with. A note of warning - you might want to have this done by an experienced tech - go ahead and spend the $100 or so to have someone experience replace the battery and keep the rest of your phone intact.
    Mark Troeller - Ответить
    The suction cup with the blue plastic handle that came with the kit did not work, but I still had the cup with the silver ring that came with an iPad repair kit and it worked nicely. Also, I found that the guitar style picks that came with the iPad kit worked best for getting the screen started.
    Bill Roughen - Ответить
    Top center worked for me best (success after 2nd attempt). Near the home button I failed constantly (I have the suction cup with the blue handle).
    Marie - Ответить
    I also found that a larger suction cup (from a Garmin GPS) which spanned the width of the glass screen worked better than the provided one.
    Robert - Ответить
    • Удостоверьтесь, что присоска плотно держится на передней панели.
    • Удерживая iPhone одной рукой, потяните вверх присоску, чтобы слегка отделить переднюю панель от задней части корпуса.
    • Не торопитесь, применяйте равномерное усилие. Модуль дисплея установлен гораздо плотнее, чем в большинстве устройств.
    • Пластиковым инструментом для открывания начните аккуратно оттягивать заднюю часть вниз, от экрана, одновременно вытягивая присоску вверх.
    • Дисплей прикрепляется к задней части корпуса пластиковыми защёлками, поэтому вам понадобится использовать присоску и пластиковый инструмент для открывания, чтобы освободить модуль дисплея.
    The suction cup didn't work, because of my destroyed front glass.
    So i take "tesa powers trips".
    With that help, i had enough force to pull up the front display from the rear case.
    ulrichstumm - Ответить
    Suction cup didn't work for me. I tried for half hour with my nerd biceps. In the end, I inserted an xacto blade below the home button to create a gap big enough for me to put in a guitar pick and finally able to pry it open. In the process I scratched the frame so you have to be very careful if you decide to take this approach.
    Meng - Ответить
    Where can you buy "Tesa Powerstrips?
    latraelmayo - Ответить
    The glass on my phone was completely destroyed, making the suction cup entirely useless. I was pretty close to giving up when i tried putting a strip of clear packing tape on the screen and squishing out all the bubbles. Put the suction cup on this and it worked perfectly.
    chriscopass - Ответить
    Thank you. I broke the front glass with this technique..
    Olivier S - Ответить
    Used a suction cup from my Garmin Navi. The one you use to stick it to your windshield. It has a nice plastic "handle" and made things a lot easier... almost too easy that I nearly pulled the screen off the cables. Go easy on this step.
    michaelychien - Ответить
    I'd Advise Against The Suction Cup Here As It Will Separate The Glass From The Black/White Framing That You're Actually Supposed To Pry Under. I Found When Using The Suction Cup, The Glass Came Up, But The Framing Stayed Stuck. If You're Replacing The Entire Display It's Not As Much Of A Problem, But If You're Installing Any Other Part Or A Custom Housing, You'll Notice Your Screen Has A Bit Of "Play" When Pressing Down.
    Mitch - Ответить
    While holding down on the lower sides of the iPhone, I found inserting the plastic separator just to the right of the audio jack while gently applying pressure down and back from the edge popped the bottom of the display assembly up. Keep in mind to do this while pulling back on the suction cup ring, like the guide says constant, but gentle force at the same time. Another note is to have the suction cup ring vertical to align with the length of the display, that made the process much easier.
    Canis Lupis - Ответить
    You rock! I was having trouble getting the thing to budge, but the moment I put the plastic tool near the audio jack, the screen immediately popped up.
    Justin -
    This should be in the guide. The front panel is actually recessed a bit here making it much easier to get a tool in at this point. No way I would have opened it without this tip. Thanks!
    dave -
    Thank you so much! This should DEFINITELY be added to the main guide.
    After struggling for half an hour and nearly giving up, I was able to easily lift up the screen once I tried to wedge it near the headphone jack!
    Thanks so much!
    diegoholt -
    I've been using a metal flat opening tool along with the suction cup to pop these bad boys open - remember the tape on the screen trick if you have a smashed screen - so the suction cup can grip and stops the glass going everywhere!
    Ben Watkins - Ответить
    Definitely a difficult step. Make sure not to pry the screen from framing. Also, I kept pushing the power button on while attempting separate the frame. Keep your fingers clear from the top of the phone because having it turn on while the casing is popped is a little nerve racking!
    Andrew - Ответить
    I had trouble with this step too, since I had to apply quite a lot of force on the suction cup when pulling up on the screen while holding down on the frame with my fingernails. Eventually it popped free, but came almost to 90 degrees before I was able to stop it. No damage, but nerve-wracking, and if there was a better technique, it would be good to figure it out and share the information here.
    Adam Engst - Ответить
    Be very gentle! I overdid it and, though the repair was successful, there's now a bit of play when pressing on the top right quadrant of the screen.
    plasticpool - Ответить
    When i was reassembling, the screen broke form the pressure. I recommend putting the screen towards your working surface and press your phone downwards. That way your screen is always straight.
    Kenichi Haramoto - Ответить
    My front panel flew right off after some puling on the suction cup - no prying was necessary.
    Fortunately, no cables got damaged. Take care.
    Leonid - Ответить
    I can confirm, the Garmin sucker cup worked like a charm. Within 5 seconds it popped open.
    Nolan - Ответить
    everything worked but i got a problem i hope anybody can help me very fast !
    when i lift the screen up it just lift the glass up not the whole display ....
    what should i do ??
    thanks in advance
    edis - Ответить
    Need extra careful while pulling the screen.
    Once there is a gap between the screen and the frame, insert the plastic opening tools and move it around the screen. But don't use it for top area (near to power button) as there is a location for flexible ribbon cable.
    Once the bottom part is free, the screen will pop out easily.
    Ardi Purwalaksana - Ответить
    Suction cup is very difficult with a cracked screen. Stick something in the ear jack and carefully push it and the edge of the screen will pop up. Use the plastic stick to open it.
    Julie To - Ответить
    I had trouble opening the screen due to a warped suction cup that was bent up at one spot and also due to my cracked screen. My solution: used double sided tape between the suction cup and the glass. I had some command strips, but I think any double-sided tape could work.
    earthhasassri - Ответить
    Use needle its a best way
    imran - Ответить
    I could never even get the case open. Waste of $30.
    dpetronis - Ответить
    The suction cup will hold if you put a piece of tape over the cracked screen.
    prattdesign1 - Ответить
    BE VERY, VERY CAREFUL, HERE!!
    -The repair went horribly wrong during this step, for me. I pulled-up on the suction cup, gradually increasing force. Instead of just opening a gap to get the plastic prying tool into, the whole thing gave way at once. This damaged the connection between the display assembly and the rest of the iPhone.
    -During this step, I would recommend placing a rubber band around the phone, over the home button and one near the top of the iPhone for good measure. Even better, invest in the "iSclack". In my case, it would have saved me about fifty bucks and three days without a functional iPhone.
    -When I reassembled, The screen was blank, but I could still sync with iTunes. I may have been able to replace only the cables, but I wasn't sure how extensive the damage was and I was done messing around with it. I replaced the whole display assembly, and now it works just fine.
    -This was STILL cheaper than buying a new phone, and I learned a lot. Overall, it was a good experience.
    peterthemick - Ответить
    1. This is very difficult, you have to use much more strength than it appears and it's very easy to rip out the connector cords. Mine did not rip, thankfully.
    2. Upon replacing the screen, I had to do this 3 times, I would not recommend putting the screws back in but turning on the phone and testing all screens before putting the panel back.
    3. When I finally managed to ensure all displays were working, I was pushing the screen back in and cracked the glass just below the home button. This part is very sensitive as it is the thinnest portion of the glass so be careful and ensure you push from the top and go all the way around. I also had to do this twice because after cracking the glass on the first try, I also realised the top was not fully pushed back.
    kkwang18 - Ответить
    We highly recommend using the iSclack tool for opening the phone up. It simply pops it up with very little effort, and you won't risk damaging your screen or device.
    Matt Gordon - Ответить
    My older phone had a swollen battery, it turns out it had distorted the display assembly enough that the suction cup only separated the screen from the display assembly. Not good.
    robin - Ответить
    I was in no mood to pay for the special tool and wait for it. Took the "right of headphone jack" suggestion and pushed down vertically at the edge of the frame with a "ice pick" sharp tool, " I had two of them. Who cares if you scratch the frame a little, I usually have my phone in a protective case anyhow. I kept working with this until the corner was up, and then the rest of the display was loose without any further work.
    primaljoy - Ответить
    My phone is in pristine condition for a 5 year old phone, I have no cracks to speak of on the glass and the suction cup that ifixit sent me doesn't stick to the glass.
    Mary Ellen Cammilleri - Ответить
    Holding the other side (top of the phone) down with another hand is extremely important. Plenty of people have damaged their screens by pulling the panel right off, ripping all the cables.
    Eugueny Kontsevoy - Ответить
    I made a series of gentle pulls and the front panel came up without problems. The opening started to appear next to the audio jack, as other people indicated. Then, I used the pry that came with the kit and the panel opened easily.
    Javier Buzzalino - Ответить
    Upon reassembly, I cracked the glass at this step. The top of the screen seemed to have too play in it and on my phone—I suspect from right side brackets that may have been damaged already. Was nearly finished and applied too much pressure? to the top of the screen area to get it back into position. Snap!
    Robert Innis - Ответить
    I pulled and pulled on the suction cup with no results then read the comments! Ugh! Found a kiosk at the mall that will replace battery for $15. Should have saved the cost of tools. They were very pretty and well packaged though! Good fortune to all that succeeded.
    Frank Fulchiero - Ответить
    Suction cup does not work. I also had to use the Garmin suction cup
    K G - Ответить
  3. Spread Fixmas Cheer
    Получите $12 за покупку от $50 и выше с промокодом FIXMAS12
    Spread Fixmas Cheer
    • Продолжайте отсоединять защёлки слева и справа от передней панели.
    while opening the front panel, i lose control and it gone so fast. And now, after putting it back, the screen is not working. What am I supposed to do? I dont have any other phone in hand and I need to repair it immediately.
    yakbu - Ответить
    as I wanted to close the display again, the sealing ring wasn't attached to the edge of the glass anymore. did someone have the same issue? thx for help!
    luc - Ответить
    I didn’t see any side clips! Could they have fallen out previously because my screen was bulging out from the case? Or did I miss them somewhere? I managed to separate the front panel from the body, but there is yet another metallic looking panel on the body. The back of the panel still attached to the front part is mirror shiny on the back of that panel.
    tom - Ответить
    Hey Tom! Unfortunately you only separated part of the display panel, try to reseat the display and open it again, paying special attention to step 3 which shows you where you should be prying to get those clips on the metal rail out of the phone body.
    Sam Lionheart -
    • Когда все защёлки снизу, слева и справа отсоединены, начните отделять нижнюю часть дисплейного модуля от нижней части корпуса телефона.
    • Осторожно расположите модуль примерно под углом 90 градусов к корпусу.
    • Не пытайтесь полностью отделить переднюю панель от задней, так как некоторые шлейфы подключаются в верхней части iPhone. Если делать неаккуратно, можно их повредить!
    When reinserting the screen, be sure to start from the top and insert the plastic tabs on the screen into the case before advancing the rest of the screen into place, finishing at the bottom. The screen will snap into place once lined up to complete the insertion.
    jeff - Ответить
    This is actually very important, I was having trouble getting the front panel to go on by starting at the top. I started from the bottom instead and the bottom ended up secure, but not the top. I then tried to take the front panel back off, but because the top portion was already loose the force required to pull off the bottom led to one of the ribbon cables at the top of phone breaking.
    jjensik11 -
    When reattaching the screen, please start from the top. BEFORE you try to push the bottom of the screen down and snap it in, use some pressure from the bottom edge to push the screen towards the top of the phone. I suggest that by the time you get to the middle of the phone (starting from the top), you do this. It will allow for getting the clips at the bottom by the sync cable clipped in and will sit nicely and allow for you to use overall pressure to make sure the whole screen is secured. I didn't do this and I damaged the seal on the right side of the phone and almost separated my screen from the digitizer trying to reseparate it to reattach the screen. Be very carefull to follow these steps I listed. If you do this while reattaching the screen, you'll have no problem.
    zhunterzz - Ответить
    I also agree with it being not necessary to remove the complete front panel. I just kept it attached and kept it at an angle as I pulled with gentle, continuous force (at a 45 degree angle as suggested) on the battery pull tab. It eventually came loose, I set the new battery in and everything works perfectly.
    Jen Robinson - Ответить
    That's the way I did it too. I put a piece of packing tape from the screen, over the top of the phone, and onto the back. That kept me from putting any pressure on the ribbon cable should the phone slip and the whole screen try to lift away from the backing.
    Ed Chapman -
    Be careful taking the front panel off. I tried to pull it very careful but it ripped. One of the cables was damaged but luckily, it was the cable that goes out with the old front panel. It also ripped 4.1 mm Phillips screw from step 13 and it jumped to the floor. I was lucky and recovered it from the floor.
    In the end everything was fine and phone works great. But remember to be super careful.
    drummerMarkku - Ответить
    BE VERY CAREFUL!! While trying to open the phone, I was must've tried a little too much and the screen came off in one shot, and it damaged the ribbon cables. Screen didn't turn on, and it cost 100$ to repair. BE VERY CAREFUL.
    Marc - Ответить
    Hello guys, I would like to first thank iFixit for these amazing repair guides they have always worked for me! Thank you!.
    When reassembling the phone make sure to put the screen from top to bottom, but be aware there are 2 small flaps on the top left side of the screen (you can notice them using another iphone as a flashlight) if you don't put these 2 flaps first then you are going to have a little space between the top part of the screen and the aluminum frame, at least this happened to me and then I inspected the screen using a flashlight and then I found these 2 tiny flaps behind the screen near the top left corner.
    I hope it helps!
    Cesar Valenzuela - Ответить
    Was it just me or did anyone else discover a ribbon cable (or something like it) on the bottom end of the phone (under the home button)? It kept me from opening the front panel more than 30 degrees or so, making the replacement impossible. Thoughts?
    Curt Jones - Ответить
    It looks like you might actually have an iPhone 5s, that is probably the Touch ID cable, check out the iPhone 5s Display Assembly replacement here!
    Sam Lionheart -
    Thank you, Sam!
    Curt Jones -
    What the heck only the top part of the lcd came off, NOT together with the shield plate. I used the stupid islack opener but only the very top layer came up. I don't see the battery or anything underneath because the shield plate is still in there. I can't even put it back closed and resuction it open because the shield plate is solidly stuck in and there is a cable at the top not settling properly. I have an open lcd top part of this phone. IDK man, PLEASE ADVISE.
    http://imgur.com/a/Qd8gp
    Gabrielle Rivera - Ответить
    Hi Gabrielle, sorry you're having trouble! This frame step was meant to show you how to avoid that issue, however, you should be able to use it to pry up the frame and shield plate. You'll need to carefully pry the frame itself up. Insert a thin prying tool between the black or white plastic display frame, and the metal phone case, to lift the frame assembly out of the phone body. If you continue to have trouble, try posting a question in our forum for faster feedback!
    Sam Lionheart -
    Hello, I've changed the earphone piece on my iPhone5 following this guide but I've skipped from step 9 directly to step 17 without problem, just shutting down first. Once opened I've tied the iPhone's body vertically to a small box with an elastic ring, the display assembly resting horizontal at some 90 degrees allows enough place to unscrew and replace the earpiece.
    Cesar Martin - Ответить
    So easy! My biggest problem is my eyesight. LOL! Had to wear glasses and use a magnifying glass. Battery took about 20 minutes. Re-installing the cover for the screen ribbons was the toughest for me. If you cant see...have someone hold the screen while you gently wrestle the screws, while holding the plate, back in.
    James Bridges - Ответить
    Worth adding to the main tutorial that the screen re-install must start from the top.
    donaldboscoe - Ответить
    I found the suction cup to be very effective in removing the front glass. Didn't take that much force to start to see the glass separate from the frame. It's a lot easier if you have a fingernail you can insert when you start to see the glass separate from the frame so that you can let go of the suction cup ring and grab a spudger to pry down one side and then the other.
    Eclectica - Ответить
    When reassembling, be sure to work from the top down to get the screen display in place. There are three hooks at the top that need to be seated otherwise they will bend and prevent the top from popping in flush.
    Wendy - Ответить
    Add a rubber band in the picture as mentioned, I couldn’t figure out how it should be positioned, also put in instructions that front panel does not have to be disconnected as I agrree with some of the other comments it is difficult to reattach the plate, although it may be a lot easier to pry the battery out without messing with the vertical top. Otherwise, great instructions, thanks Ifixit,new iPhone battery is wonderful. Bil - 1/16/2018
    William Doherty - Ответить
    • Удалите следующие винты, крепящие шлейф модуля к плате:
      • Два винта 1,2 мм Phillips (крестовые)
      • Один винт 1,6 мм Phillips (крестовой)
        • Не работайте с этим винтом намагниченной отвёрткой, не потеряйте винт при вскрытии и удостоверьтесь, что вернули его на правильное место — намагниченный винт может помешать работе компаса!
    Anyone have any idea why the 1.6mm screw is not magnetic? Just wondering why this screw seems to be made of aluminum, its the first screw of its kind as far as iphones go.
    crevz - Ответить
    The compass is right next to it.
    Tom Chai -
    I'd recommend if they made that clearer in the guide, luckily I put them back in right, its the one with the little bit of blue on it if i recall that isn't magnetic
    Matt -
    is it necessary to disconnect the front panel assembly cables fore removing the battery ?
    or can you leave it on wile replacing the battery ?
    aardappel - Ответить
    I just finished this process using the battery replacement kit from ifixit and it went easily. I did NOT remove the entire screen but rather just had someone hold it at less than a 90 degree angle until I got the battery out. I found it took a while to slowly pry the battery out. Take your time and alternate between gently using the plastic tool and pulling on the plastic pull tab that says "for authorized use only" or something like that. It was MUCH easier than disconnecting the entire screen for the process. Hope this helps.
    david -
    Rule #1 on electronics repair methodology: to prevent damage to the electronics, power should be the first thing to be removed and the last to be restored. I'd disconnect the battery before touching anything else, a slip of the screwdriver or a loose screw could cause a fatal short circuit.
    andrewcilia - Ответить
    It's no need to remove front panel to change battery. I just skip to Step 10 and successfully changed battery, and it works well. And THANKS TO ifixit.com, IT IS AWESOME!
    sorrowboy - Ответить
    I skipped steps 6-9. leaving the screen attached to the phone makes it that much easier and quicker to repair
    Frank - Ответить
    Mon téléphone a pris l'humidité et présente un fond d'écran d'aspect granuleux. Du coup l'éclairage n'est plus uniforme, nuisible pour une bonne lecture de l'écran.
    J'ai démonté l'écran, une pellicule grasse et collante entre le LCD et la plaque métallique. J'ai nettoyé à l'alcool. Tout remonter avec la crainte que le téléphone ne fonctionne plus.
    Le téléphone s'est rallumé, tout fonctionne normalement mais j'ai toujours ses traces sur le fond d'écran. Il faut le changer!
    Mes difficultés étaient de remettre les petites vis aimantés, difficiles à remettre!
    Merci à IFIXIT pour ce tutoriel très explicite.
    Patrick Rosa, june 23 2014
    pkrosa - Ответить
    So, of COURSE I dropped the screw that you are not supposed to lose. I was being careful, but as I did not want to lose track of it, I attempted to put it back ing the phone FIRST. Bad idea. This makes the plate kind of springy, and my screwdirver slipped, and the screw popped up, spun in the air, fell between my legs, bounced off my padded chair, and clattered around on the floor. I searched for an hour, and could not locate it. BE IT KNOWN, at least in MY CASE, the screw WAS INDEED attracted to my magnet (I keep a powerful round magnet stuck to the shaft of my drivers to provite the magnetism, far more powerful than a regular magnetic screwdriver. This being the case, I WAS able to provide a substitute fron a bag of iphone 4 screws, and my compass calibrated flawlessly upon power-up. YOUR MILEAGE MAY VARY, but I thought I'd add my experience.
    stevesontheroad - Ответить
    Be warned, the 1.6mm screw is exceptionally easy to strip. I haven't been able to get it out yet (already tried rubber band trick and a few others) and am on the verge of giving up. The #00 screwdriver that comes with the set did not do a very good job of catching.
    joseparra947 - Ответить
    Were you ever able to get it out? Mine seemed stripped from the get go, rendering my attempt to troubleshoot my blank screen fruitless. Rubber band, glue, flat-head all did not work for me. Buying a soldering iron tomorrow to try that.
    randypalmerjr -
    I did the repair without disconnecting the screen. I skipped down to step 13 and carefully held the screen while removing the battery. Adds a small element difficulty, but helps prevent all the issues others are having when reconnecting the screen.
    The non-magnetized screw was very difficult to install. This is how I ultimately succeeded:
    Install the two magnetized screws first. They are easy because the magnetized screws will stick to then end of the screwdriver. They will hold the cable bracket in place.
    Place the third, non-magnetized, screw on the center of the cable bracket. Take a toothpick and nudge the screw toward the screw hole. The threaded part of the screw (the shaft) has enough weight that it will fall into the hole, and the head of the screw will be pointed upward. You will then be able to use the screwdriver.
    alsmith1928 - Ответить
    Put a piece of tape on the table sticky side up. Set the screw on the tape head down. lift the tape and guide the screw in place. drive the head of your screw driver through the tape and tighten screw. lift off tape. throw away. :)
    rdgentry -
    The tape trick works well. Another way is to dip the screwdriver in alcohol (isopropanol, do NOT use water) and put the screw on its tip. It will be held there until the liquid is evaporated, which should be sufficient to put it in place.
    Kater_S -
    One of the screw is completely stuck and I cannot remove it! What can I do?
    stefanoclearmounth - Ответить
    When putting it back together, I replugged in all three of the ribbon cables and powered on the phone to test before putting everything back together. All was OK except for the Home button, it had no effect when pressed. I ended up unplugging and replugging the 3 ribbon cables a few times and retrying. I then cleaned the connectors using a can of compressed air, screwed the little silver cover back on and snapped the whole phone back together, hoping everything would be fine. It was. I don't know if the problem was a dirty connector, or if you need to close the phone to make the home button work again.
    I recommend wiping the plastic prying tool after lifting the screen off, it gets dirty from the gunk build up and some of that could eventually fall inside the phone.
    My battery was really stuck, so much that the plastic tab broke when pulling. I followed someones advice to heat the back of the phone with a hair dryer, still wasn't super easy but I managed to get the battery out, only deforming it slightly.
    grosstua - Ответить
    The contacts for the home button are on the phone base so the screen needs to be in place for the button to work..
    Liam Carson -
    Step 9-12 are totally unnecessary unless you need to replace a broken screen. All you need is to keep the front panel in a vertical position once the front is open. The battery can be removed without taken out the 3 connectors which by the way the screws are very very tiny and difficult to put back.
    rich1812 - Ответить
    I completely agree. These are unnecessary steps. Might be a little easier to pry the battery out with the display completely off, but not enough to make it worthwhile IMHO.
    davidmeyers -
    Is the 1.2mm a #000 or #0000? I have a small set and can't get one of these out. The instructions say a 1.2mm, the tools list shows #000, but my set says #000 = 1.5mm.
    Kevin - Ответить
    1.2 mm refers to the length of the screw (from head to end), the screw head size is compatible with a Phillips #000 driver. So as long as you have a #000 you should be set! Good luck =)
    Sam Lionheart -
    Invest in and use some colored Sharpie Pens... I color the tops of the screws orange and red etc. to match the colors of the circles in this guide. Then when I go to put them back in there's no doubt as to which screw is the correct size.
    Pete H - Ответить
    What an idea, lol.
    bigfnevil -
    frustrated...screws to battery holder is stripped, now what?
    Martin Gonzalez - Ответить
    Maybe a small amount of loctite. I noticed the P2 screws holding the display down had a small amount on my iPhone 5.
    Steve Heigh -
    Como se ha comentado más arriba, no es necesario desmontar la pantalla, yo he sustituido la batería aplicando calor con el iOpener y siguiendo atentamente la guía. Resultado óptimo.
    Yes, right! I, too, do not see the need to remove the LCD display at all; except, when one is replacing a broken display. The battery is ready for replacement once you had removed its bracket.
    valuesphilippines - Ответить
    I found that it wasn't at all necessary to remove the front glass. I did need to use a hair dryer to soften the glue holding the battery, but I simply laid the phone down on the face glass and blew the hot dryer on the back for a couple of minutes at almost point blank range. Then I simply held the phone open with one hand, making sure the front glass never went back more than about 80 degrees (no need to stretch it all the way to 90 degrees), and used my other hand to work the spudger around the battery, making sure not to touch any delicate electronics in the area. The top right corner gave away first and then I worked it down from there and the battery came out pretty easily. The trick is to use the hair dryer for a few minutes beyond the phone being too hot to hold in your hand! (you might need to use a towel to pick it up when you pry the battery out.)
    The battery of my 2012 iPhone 5 was working well but started to inflate pushing the front panel assembly out from the case. Replacing is faster and easier than on iPhone 5s. No need to remove the front panel completely, just holdig it at near 90º is enough but needed to warm the case to soften the battery glue. Thanks to iFixit for this guides and you guys for your comments.
    As other people already indicated, steps 13 to 16 are not needed and risky. I asked another person to hold the front panel at 70 degrees while changing the battery.
    I rushed in and did steps 13 to 16 without reading the warning. There were some unexpected events that happen. The short version of this story is my screen comes up with funny looking grey squares but phone is still usable. I don’t care as my main phone is an iPhone SE and I bought the battery as a learning exercise. Plus iOS 11 doesn’t install on an iPhone 5 so it’s days are numbered as a productivity tool.
    Long version. Dissemble was easy. I made sure I had used the phone so the battery was warmed up . First problem with reassembly is in step 13 the bottom most 1.2mm wasn’t biting and screwing in. So it looked like the top of the hole got threaded. Also a screw fell out of what I think is the loud speaker. That was unexpected. This iPhone 5 isn’t my original, it was a replacement phone that came in a white phone that the Apple Store gave me when my original phone from 2012 had 2 recalls on it. So I strongly suspect this is a factory refurbished phone and not 100% mint off the line.
    Ignatius Tse - Ответить
    • Отключите коннектор шлейфа дисплейного модуля от платы.
    • Замечание: Удостоверьтесь, что вы опустили и оттянули маленькие крепления к внешней стороне телефона.
    My iPhone 5 (1428) model don't has this bracket and replacing the earpiece don't fix my problem (don't hear anyone).
    plyhell - Ответить
    You might check that front camera flex cable.there can be a damage also where war speaker connects
    Vinayak Devadiya -
    Great Guide, Any idea what else could be wrong if Ive replaced the screen with a working 1 and the phone still has no display?
    Thanks for any insight in advance.
    Raistlin - Ответить
    When you reverse step 7, make sure you clip the little hooks of the bracket under and then lower towards the outside of the phone. If you don't, the phone won't snap back together properly.
    Dirk - Ответить
    I've misplaced this metal plate AND the three screws and two pentalobe screws. I think my wife threw out the ziplock I had them in. Any chance you can tell me where to get them? thx
    Don - Ответить
    Don't forget to clip this in flush, my phone couldn't get a cell signal when it was slightly out-of-place.
    julian - Ответить
    Remember to put this plate back such that it's sitting evenly. The side towards the battery some times tends to stick up a bit, this in turn will put pressure on the backplate of the screen. After putting everything back together, you see a small yellow smear just to the left of the battery % indicator, you have not put that plate on correctly. Open up the phone, remove that retention plate and put it back such that it sits properly!
    AGS - Ответить
    Opened my iPhone 5 etc. When reassembling, I notice the screen doesn't stay clipped into the back tray and is raised a couple of mils.
    There is also a new brighter spot on the screen. Any ideas anyone?
    Ian Campbell -
    I really wonder about the wisdom, and risk, of removing this upper plate in step 14 - unless I missed it, those three cables are NOT connected to the battery in anyway - and the chances for stuffing up said cables re-assembly are moderate to high! I can see that one would have to be careful taking that bracket and disconnecting those three cables ( I certainly was), but it looks to me like there's a case for just undoing the battery bracket & screws and carefully - very carefully - with great patience and some good spudgers, esp the black ones we use in desktop iMacs, - flat one end; pointy the other - plus the usual blue plastic ones and even a guitar pick - prying the battery out from its hideyhole! Much less stress regarding the upper bracket and the three cables while only a bit more stress over releasing the battery from its sticky grip! Anywho, I might have to stand corrected - but next time I'll go for this abreviated method. :)
    amicuset - Ответить
    please do not do this part....after you remove the bracket over the battery don't mess with the 3 cables at the top or remove its bracket. Just carefully remove the battery and insert the new one. the idea of using the rubber band helped a lot with the entire procedure and i did it in one very easily. thank you ifixit and most importantly the comments. Make sure to read all the comments before doing each step even when you r reassembling.
    Anderson Ashby - Ответить
    I confirm the previous post! It’s the third times I change the battery and I just realize this time that it’s completely useless to remove the front panel. You just have to be careful if it’s your first battery change because the original one is strongly sticked on the board. Don’t be brutal! Proceed slowly.
    I think that lots of problem may occur when you reassemble the front panel cables. So just don’t disconnect them !
    Ifixit is great. The comments are usefull too.
    jproubin - Ответить
    I also made the mistake of trying to remove the cable bracket. Once again I had to resort to another screwdriver since the included 000 in the battery kit did not work on these. But once I got the three screws removed I noticed the bracket’s top corner (near the top of the unit) was stuck even when I properly pulled the bracket back to unhook the lip from the logic board. I tried pulling it free every which way but nothing seemed to work so that’s when I checked the comments here and realized I shouldn’t have even bothered trying to remove it.
    Clay Withrow - Ответить
    Can I leave the bracket out? Does it have any shielding or antenna function? It’s hard enough to get the replacement screen in without it…
    Andi - Ответить
    I agree, it is not necessary to remove this cover or the cables underneath. nothing is covering the battery so just pry it out. I had the battery changed in less than 10 minutes.
    chriswood - Ответить
    • Используйте пластиковый инструмент, чтобы отключить три шлейфа передней панели:
      • Шлейф фронтальной камеры и сенсора
      • Шлейф дисплея
      • Шлейф цифрового преобразователя
        • При обратной сборке телефона шлейф дисплея может отойти от разъёма. Это проявляется в белых полосах или отсутствии изображения на дисплее. Если это произошло, просто переподключите шлейф и перезагрузите телефон. Лучший способ перезагрузить телефон - отключить и подключить батарею.
    The part itfixit sent only has two cables: the digitizer and LCD are combined into a single cable. (And the guide is great! Thanks!)
    baileyswanson - Ответить
    After replacing the screen I was presented with a no image screen (but backlight was ok), so I refited the shartered one, same issue, no image, but backlight. thinking I might damage the pcb, I just did a power cycle (disconnecting the battery) and now it's fine.
    so... always powercycle :)
    poseido - Ответить
    Be very careful here, at this point the phone power is live! a slip of the connectors or a loose screw could let the magic smoke out of the chips (chips won't work without their magic smoke, you know :-)
    I'd disconnect the battery before messing with the connectors.
    This is a troublesome step, since the LCD connector is particularly difficult to reconnect, and know that you've gotten it on. And thanks to the note claiming that if it's disconnected, if you might just get a black screen, you're left with having to disassemble the entire unit again, without knowing if it's powered off (since you presumably tried to power on). That's also nerve-wracking. I had this problem and disassembled and reassembled the entire phone, only to have the problem again. On the second try, I plugged the phone into power, and after a little bit, got the dead battery screen showing. So the problem was that the battery was discharged, not that I'd biffed the LCD connector.
    The hint to disconnect the battery was very useful for my successful repair. After rebooting the phone everything was working just fine. Thanks!
    benjaminjrichter - Ответить
    BE CAREFUL HERE.
    Take a good look at that camera loosely sitting there. It is possible that it will be slightly offset when shutting the assembly back into place. This causes it to not properly focus on closeups. If you don't move it around you will probably be okay.
    Also, look at the display assembly, it has three small locking tabs that can bend easily if not pushed in at the right angle into the iPhone frame. Be careful not to be too forceful. Good luck.
    info - Ответить
    I am having issues removing the white lines on my screen. I made sure to connect the digitiizer connector was seated all the way and I also power cycled my phone several times. Anyone else having this issue?
    eric51redding - Ответить
    If your lcd is properly fine then it can be a LCD Ic issue on pcb
    Vinayak Devadiya -
    When I was reassembling this the front facing camera cable was a bit longer than the previous one. I had to kink the ribbon cable a bit to get the connection to line up. Everything seems to be working but I wanted to note that the part might be slightly off spec.
    Aaron Martina - Ответить
    I am very satisfied with the replacement display assembly (including FaceTime camera and Home button) iFixit sent. It arrived a day early, fit perfectly, and has fixed the color banding, cracked screen, and scratched edges very well. In addition, the home button now has a much crisper "click" to it, more like the new MacBook's keys vs those of an older MacBook Pro.
    Nathan Jones - Ответить
    This step is not needed to remove the battery and complicates the process by having to reconnect the sensors.
    nicholaskan - Ответить
    if my lcd metal plate is scratched can i replace it to remove the lines or do i need a new lcd
    brittany stapleton - Ответить
    When I started the phone again, there was a grid pattern and touch was not working consistently. It turns out there were two separate problems. (1) We had over-handled the cables and a quick swab of alcohol helped remove the oil from the connections. (2) The first connection is really tricky to get right and comes undone easily during the final reassembly.
    Jeannie Crowley - Ответить
    I had this problem too (not the oil though). When I first restarted the phone, I had white crosses over the display, and the digitiser didn't work. The only way to shut down the phone was to hold the home key & power key for 8 seconds until the display went black. Reseating the LCD & Digitiser connectors, and power cycling by reconnecting the battery fixed the problem. Hope this info helps others.
    Tom Hannen -
    In the image you can see the camera has lifted out a bit. Mine did this too, because the old screen had levered it out. To push the camera back into position you need to insert a fine tool behind a small metal spring contact because it catches on the camera's casing otherwise. This little spring is to the left of the metal case, between the camera and ribbon.
    pauldevans - Ответить
    Great pics too. Pls confirm if the three photos in Step 15 only show removal of 2 of the 3 connectors mentioned in the instruction (and colored bullets). I could not tell which was the third one to remove in the three photos. Thanks!
    gandarlmg - Ответить
    So I keep getting the "white lines on the LCD" bit with no resolution. I've tried reconnecting the connector like 6 times and power cycling and I get the exact same thing every time? Is it possible that the replacement screen has an issue?
    Jared Spencer - Ответить
    May I ask what the 4th little connector is that comes from under your battery and connects to the board mine came undone during repair and won't go back in
    Cameron - Ответить
    Watch the soft pad between the rear camera enclosing and the top side of the frame, especially when reassembling. After replacing the battery, my camera pictures gradually showed lots of dust spots. I opened the device again and discovered that the pad had been displaced. However, I am not fully sure if that is the reason for the spots.
    Kater_S - Ответить
    On reinstall, I can't get the connectors to line up and the replacement screen has 3 connectors where as my busted screen had only 2. The cables on the replacement screen are too short? Is that even possible?
    maryann miller - Ответить
    I’d say removing the screen is BS. I realized that I didn’t have to remove my screen cable as I was able to flip the screen vertically while I take the battery out. Removing the screen cables causes more problems- you may end up with white squares on the top of the screen which seem to expand over time. Also it is very easy to bend little metal legs on the socket when prying the connector.
    kimgcp08 - Ответить
    totally agree, no need to remove the screen. It means you will have to do everything with only one hand (the other one is holding the screen), but you skip so many steps that overall it’s well worth it.
    Metafisco Parapensante -
    It is very important to make sure the cables are fully seated. When I finish assembling the phone I too had a vertical white stripe on the display. I disassembled the phone and reconnected the cables very carefully, and also made sure the shield was properly seated. When I turned the phone back on I found a very faint white line, but after doing a power cycle it disappeared to my great relief. Also, I would definitely recommend removing the display because it’s so hard to get the battery out you don’t need the extra risk of damaging the display.
    After replacing a friend’s iPhone 5’s rear camera and reassembling their phone the screen displays verticle black lines on the right side now like this: http://i1091.photobucket.com/albums/i393...
    Anyone else have this problem? I didn’t think about cleaning the display connectors with alcohol at the time.
    Ken Shimabukuro - Ответить
    Also, when the battery was too low and before the display produced vertical lines the display showed half of a low battery symbol:
    Like the right side of the display was blank.
    Ken Shimabukuro -
    On reinstalling the front panel assembly, I had a difficult time lining up the digitizer cable. After struggling with it for a while, I noticed that the plastic shoulders of the small mounting bracket at the ends of the pins had become rounded over. After cleaning these up with a razor blade, everything slid together perfectly. Thanks so much for these guides and all the helpful comments!
    Dave Martin - Ответить
    I have done all these operations 6 times to get back a good displaying. The last was the last: nothing on the screen now. It is now black, no sound, no vibration, BUT the iPhone show up in iTunes O.O
    iTunes asked me to update the iOS to 10.3.3 but it’s already done. I clicked OK but nothing more. Still black and quiet.
    The new battery is 100% charged.
    What is my problem, please help :-(
    franck.bremeault - Ответить
    I found the part who was deffective: the connector of the screen has broken due to too much movements. :-( Screen is perfect and clean but dead.
    franck.bremeault -
    • Снимите переднюю панель.
    My display was not turning on and my home button was not working (I verified this by trying to activate siri which didn't work). When I replaced the display assembly everything works except for the home button. Since this assembly comes with the button and the ribbon cable, I'm not sure what else can be wrong. I checked the contacts on the phone and I see the little copper 'pins' sticking out. I can't tell if they are making contact since the display has to be closed, but it appears they are lined up correctly. Does anyone have any suggestions or ways to test the contact pins? Could the home button on my replacement be defective? I've already emailed support, but just curious if anyone has any suggestions I could try while waiting to hear back from them. Thanks! By the way, SUPER grateful the rest of the display works. I can now back up my phone and can probably deal with a broken home button if I need to. Woohoo!
    jhagerman - Ответить
    I'm having issues where the screen jumps around when you get a finger near it. I'm reading it might be grounding but no idea where any tape could be applied. Replaced the screen twice thinking it was a bad part. Now, I just don't know.
    Ana Van Meter - Ответить
    My front camera does not work. I took apart and ensured the connection several, several , several times.... no front camera... anyone else have this issue?
    Patricia Young - Ответить
    Try replacing the camera and flex assembly.
    Greg M -
    • Открутите два винта, крепящих держатель фронтальной камеры к модулю дисплея.
      • Один винт 4,1 мм Phillips
      • Один винт 2,2 мм Phillips
    I just replaced mine on 10/6/13. WARNING: the black plastic spacer for the upper screw could come loose when taking the bracket off. Be very careful.
    cappich - Ответить
    Can anybody measure the spacer height for me? I have the phone where it is missing. I have even been to service place to ask for it, and they claim there is absolutely no other small part under earpiece speaker. I guess I'll have to make some replacement from hard plastic. I can't seem to find it in any online store.
    Adam -
    You can find it on eBay. It is sold along with the two clear plastic pieces.
    Greg M -
    The 4.1 mm screw has a blue line on it. This may help with organization.
    Timmy McInerney - Ответить
    • There is a small, black plastic spacer underneath the metal bracket at the upper screw. The upper screw goes through the metal bracket then through this plastic spacer.
    Use a hair-dryer on low heat to loosen the glue around the speaker cover. Also, don't forget the small clear plastic holder for the camera
    Tady Walsh - Ответить
    This should really come after Step 16
    Drew18 - Ответить
    This seems to be in the wrong order. The picture shows parts removed that are instructed to be removed in later steps.
    Kenny Evitt - Ответить
    I don't know what's going on here. First, it seems like this instruction is in the wrong place -- it should be a few steps later. Second, the phone I was working on did NOT have the piece described. I don't know if that means that the phone was screwed up before I got it apart, or whether there was some change to the design to the iPhone that some models have this piece separate, and some models don't. As far as I can tell, the proximity sensor works after reassembly.
    Adam Goldberg - Ответить
    I replaced my battery and ever since then my front facing camera does not work and after a while my back camera is not working nethier does the microphone where I hear people talk on the phone why is this please help
    Kulli Kalervo - Ответить
    When replacing the battery, be careful not to open the LCD more than 90 degrees. You may have damaged a flex cable assembly or possibly the connector may not be seated correctly, although unless you removed the connector cover, that is unlikely. Or if you had to pry the battery out, you may have damaged something else. Since the cameras are on different connectors it doesn't sound like something simple.
    Greg M -
    This step should be after step 20. It is fitted under the earpiece speaker,
    ghschroder - Ответить
    I believe you (and the other commenters who pointed this out) are correct! I went ahead and shuffled the order of the steps. Thanks for the heads-up.
    Jeff Suovanen -
    I agree with you guys. This step should be after the camera and sensor cable are removed. It's much easier to get at. Cheers fellow fixit's
    Wayne Lyell - Ответить
    did you sell the plastic spacer ? if yes, how much?
    Hrahmi - Ответить
    you can also see the front facing camera soccer/positioning piece of plastic (clear plastic circle) this needs to be removed also and placed into the new display.
    laptop - Ответить
    Be VERY careful with this spacer! When i picked it up with the tweezers to put it back in, it shot out of the tweezers! I finally found it - but it was a tense half hour!!!
    Theresa Biggs Greenan - Ответить
    • Снимите держатель разговорного динамика с модуля дисплея.
    There is a tiny black plastic spacer under the top screw, be sure not to lose this. It is easier to reinstall it after all of the parts have been transferred to the new screen including the front facing camera assembly. The spacer has a small cutout in it, which is positioned to the left side. Put this spacer in as the last step before reinstalling the metal speaker bracket, otherwise you risk losing it moving the screen around reattaching all the parts to the new screen.
    crevz - Ответить
    Hello, Do you have a photo of this as I'm still unsure to where it goes.
    Thank You
    Jordan Baker -
    ehm, you can leave that out just fine
    Fixandinstall -
    One additional note to the above comment, the gap in the little spacer goes on the left, but the flat side of the spacer goes on top. Took me a few minutes to figure out that orientation.
    vhfreak - Ответить
    what happens if i lost the small plastic spacer? and where can i buy it? ty
    HandyGarage - Ответить
    Same here and could not find answers. Basically without this wicked little plastic bastard I can only make calls via headphones? What a faulty design.... Maybe loosening the screws can help? Or using something plastic or paper on that place with similar size?
    More annoying than soldered parts I swear...
    szikszai70 -
    • Снимите разговорный динамик.
    There a small square black plastic "gasket" next to the 2 copper contact points. Be sure it is back in place before putting back the screws holding the earpiece speaker in place.
    Rany - Ответить
    It is a site of iPhone 5 Earpiece Speaker Replacement .I have visit the site Its photos are very nice and relevant like a site <a href="http://www.reasonablegifts.com/">Iphone 5 cases</a>
    Lee Ratliff - Ответить
    Took about 2 hrs to finish. First I left the red film on after placing the LCD plate. I unscrewed and took the film off. The tough part was placing the front camera and earpiece speaker. It took me sometime to understand that one of the cables fold to sit in its position. Tested the camera and phone call. All seems to be working fine.
    sathyajsn - Ответить
    I torn (ripped ) my earpiece speaker contacts ( two metal dot ) , how can I repair them ? Thanks
    bulentkucuk - Ответить
    You will need to replace the flex assembly.
    Greg M -
Заключение
Следуйте этим инструкциям в обратном порядке, чтобы собрать устройство.
188 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Jasper Fleischhauer is helping us fix the world! Хотите внести свой вклад?
Начните переводить ›
Andrew Optimus Goldberg
Участник с: 17.10.2009
394 811 Репутация
Автор 412 руководств
Команда
iFixit Member of iFixit
Community
113 членов
Автор 7 348 руководств
Комментариев: 9
Hello folks,
my iPhone stopped working, diagnostic as follow:
Need to switch to speaker or use headphones to call, since caller can hear me, but I cant.
Please tell me that its not a chip failure.
thx :)
umweltverschmutzer - Ответить
I decided to examine the problem before ordering the new earpiece speaker, so performed the disassembly first. At Step 13, I found that one of the two screws holding the bracket was already completely loose. Everything else checked out visually (the spilled wine that I'd worried about was nowhere to be seen), so I reassembled. Bam! Working just fine, no new part needed.
gregoryhayes - Ответить
worked for me also. issue was that the 2 gold coils on the back of the ear-piece (which you will see after you disassemble parts) were contracted. Simply extended them out a little by pulling with gentle force, this will re-enable them to earth properly against the gold plates.
GH Sales -
Also worked for me. iPhone 5C, 2 years old, ear speaker stopped working.
Like GH Sales all that was required was pulling on the two gold springs on the back of the earpiece speaker. This fixed the speaker problem for me.
Jakub -
Had the same issue, what GH Sales did worked for me!
Angela Penaherrera -
ordered the parts with a new battery, new set of screws and a new ear piece... battery is fine but earpiece still doesn't work...
dechdez - Ответить
I replaced it with a new speaker, but despite this I still hear very low, I add that before the issue I had also changed the flat proximity sensor with the circuit and the front camera, could be this the problem?
Andrea Sgambato - Ответить
Hello, I had replaced my earpiece speaker half a year ago at a repair store, then it seemed to work again but a day later it stopped working again. They told me it wasnt their fault because it worked yesterday. So i got basically nothing for my €39. Before then en after it got replaced I always used earpods or the bottom speaker, but i was quite fed up with the fact i have to make phonecalls this way. So I ordered a repait kit with a new earpiece speaker (The previous speaker came from another broken iphone 5) and repaired it myself accordingly. But it still doensnt work, I have no idea what the issue might be... anyone any suggestions? I dont really want a new phone, since I dont really have the money, and Im still pretty pleased with my iphone 5
12chrismi The Legend - Ответить
Hi!
I replaced new digitizer and display for my iPhone 5 and I lost that little plastic spacer between ear speaker and bracket. Where I can buy new one? In europe.
Добавить комментарий
Просмотр статистики:
За 24 часа: 17
За 7 дней: 108
За 30 дней: 458
За всё время: 207,488
