Введение
Internal prerequisite to remove the lightning connector and speaker assembly
Выберете то, что вам нужно
Remove the following screws securing the Lightning connector and speaker enclosure assembly to the rear case:
One 2.5 mm Phillips screw
Two 3.3 mm Phillips screws
One 2.9 mm Phillips screw
Two 1.5 mm Phillips screws
One 2.8 mm Phillips screw
Use the flat end of a spudger to gently pry the Lightning connector and speaker enclosure assembly cables up from the rear case.
Remove the Lightning connector and speaker enclosure assembly from the rear case.
