Выберете то, что вам нужно
Remove three screws securing the vibrator and vibrator bracket to the rear case:
One 2.3 mm Phillips screw
One 1.7 mm Phillips screw
One 1.6 mm Phillips screw securing the vibrator to the top inside of the rear case.
Remove the following screws securing the volume button and ringer switch brackets to the side of the rear case:
One 1.5 mm Phillips screw
Two 1.8 mm Phillips screws
Use the tip of a spudger to pry the ringer switch bracket from the side of the rear case.
Remove the ringer switch.
Use a spudger to pry the volume button bracket from the side of the rear case.
Remove the volume buttons.
Еще один человек закончил это руководство.
