Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Power off your iPhone before beginning disassembly.
Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
Инструмент, используемый на этом этапе:iSclack$24.99-
Close the handle on the iSclack, opening the suction-cup jaws.
Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
The top suction cup should rest just above the home button.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
Skip the next three steps and continue on to Step 8.
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
In a pinch, you can use an unopened canned beverage to hold the display.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
Remove the metal battery connector bracket from the iPhone.
Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
Two 1.3 mm screws
One 1.7 mm screw
One 3.25 mm screw
Remove the front panel assembly cable bracket from the logic board.
Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press the SIM card eject tool inwards to eject the tray.
This may require a significant amount of force.
Disconnect the Lightning connector ribbon cable from its socket on the logic board.
The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
Disconnect the antenna connector from the base of the logic board.
Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
Disconnect the rear facing camera cable connector from its socket on the logic board.
A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
Инструмент, используемый на этом этапе:Standoff Screwdriver for iPhones$5.49-
Remove the following screws securing the logic board to the rear case:
Two 2.3 mm Phillips screws
Three 2.7 mm standoff screws
One 2.5 mm Phillips #000 screw
Remove the 1.2 mm Phillips #000 screw securing the grounding clip to the top side-wall.
Use tweezers to remove the logic board grounding clip.
Use a plastic opening tool to gently lift the lower end of the logic board up from the rear case enough for you to grab it with your fingers.
Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
Flip the logic board up toward the volume control buttons to expose the antenna connector.
Disconnect the antenna connector from the back of the logic board.
144 участников успешно повторили данное руководство.
14 Комментариев
Would a logic board swap be easier than a battery swap between 2 iPhone 5C's? ?
A battery swap would be significantly easier! Here's the battery replacement guide. =)
While I was repairing my phone, I guess the part where I didn't go around was taking out the battery because it felt like it was the more fragile part. This was because I did not have the proper equipment to take it away. This guide was pretty helpful for me in reconnecting cables.
Anyway, I am bothered that as I took out the logic board, there was this golden thing that just slid out of place. It slid from the top portion of the phone, but I do not know where it was originally and I do not know how it was supposed to be placed. It looked like an open box of sorts (but only had 3 sides bent up) and had a hole in the middle. It would be great if anyone would know where it could be placed so I could put back my phone.
Look at step 29 :)
Where i can buy this board for iphone5c
