Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
Disconnect the rear facing camera cable connector from its socket on the logic board.
A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
Remove the following screws securing the logic board grounding clip to the rear case:
1.2 mm Phillips #000 in the top side-wall
2.5 mm Phillips #000
Инструмент, используемый на этом этапе:Standoff Screwdriver for iPhones$5.49-
Remove the following screws securing the logic board to the rear case:
Two 2.3 mm Phillips screws
Three 2.7 mm standoff screws
Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
Flip the logic board up toward the volume control buttons to expose the antenna connector.
Disconnect the antenna connector from the back of the logic board.
