Введение
Use this guide to remove or replace your GSM iPhone's SIM card and tray.
Выберете то, что вам нужно
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press the SIM card eject tool inwards to eject the tray.
This may require a significant amount of force.
42 участников успешно повторили данное руководство.
2 Комментариев
How would you replace the sim card try if the tray is jammed? Is there a way to open up the phone and replace it internally?
You can try opening the phone and removing the SIM eject lever, or seeing if its obstructed somehow, with this guide. good luck!
