Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Today's teardown subject will be this iPhone 5s dock - it's visually similar to the other docks from the past, but with a Lightning connector instead.
This looks like an indented iPhone 6 dock.
This iPhone dock is perfectly indented to fit an iPhone 5s.
Some (weaker) adhesive covers the bottom and it's a simple task to take it off using a spudger, or another flat, flexible tool.
Use a spudger to carefully detach the cover from the base.
You can now remove the two screws that secure the weight to the plastic housing.
