Введение
prereq only (full home button guide includes removing gasket)
Выберете то, что вам нужно
Remove the two 1.9 mm Phillips screws securing the home button bracket.
Use the point of a spudger to disconnect the home button cable connector by pushing it up and away from the home button.
Инструмент, используемый на этом этапе:iOpener$19.99
Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
Peel the home button the rest of the way off of the display by prying gently with a spudger.
Инструмент, используемый на этом этапе:iOpener$12.99
Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
Once all the adhesive has been separated, remove the home button from the front panel.
9 участников успешно повторили данное руководство.
Один комментарий
Home button robin cable malfunction after replaced.
Replaced broken Home button robin cable, now the phone will not turn on unless I unplug the home button cable from the mother board! I've thought of placing the phone in recovery mode and placing the phone in factory setting then trying to reconnect the cable, BUT to do that the home button has to be WORKINGand it's NOT working. Also the phone as the current iOS on it... Any ideas other than buying a new home button cable and trying the replacement again?
