Введение
Prereq only, battery removed.
Запчасти
Детали не указаны.
Remove the following screws securing the antenna bracket to the rear case:
One 1.5 mm Phillips #00 screw
One 2.8 mm Phillips #00 screw
Carefully pry the antenna connector up off the logic board with a plastic opening tool.
Grasp the antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board.
Disconnect the power button cable and audio control cable connectors from their respective sockets on the logic board.
Remove the following screws securing the top cellular antenna to the rear case:
Two 1.6 mm Phillips #00 screws
Use a pair of tweezers to grasp and remove the top cellular antenna out of the iPhone.
2 участников успешно повторили данное руководство.
