Введение
Prereq-only guide to disconnect the battery.
Выберете то, что вам нужно
Remove the following screws from the battery connector bracket:
One 2.3 mm Phillips #00 screw
One 3.1 mm Phillips #00 screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
5 участников успешно повторили данное руководство.
