iPhone 6 Plus Earpiece Speaker Replacement
Выберете то, что вам нужно
  1. iPhone 6 Plus Earpiece Speaker Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Plus Earpiece Speaker Replacement, Anti-Clamp instructions: шаг 2, изображение 1 из 3 iPhone 6 Plus Earpiece Speaker Replacement, Anti-Clamp instructions: шаг 2, изображение 2 из 3 iPhone 6 Plus Earpiece Speaker Replacement, Anti-Clamp instructions: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Plus Earpiece Speaker Replacement: шаг 3, изображение 1 из 3 iPhone 6 Plus Earpiece Speaker Replacement: шаг 3, изображение 2 из 3 iPhone 6 Plus Earpiece Speaker Replacement: шаг 3, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Plus Earpiece Speaker Replacement, Front Panel Assembly: шаг 4, изображение 1 из 1
    • Use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Plus Earpiece Speaker Replacement: шаг 5, изображение 1 из 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Plus Earpiece Speaker Replacement: шаг 6, изображение 1 из 2 iPhone 6 Plus Earpiece Speaker Replacement: шаг 6, изображение 2 из 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Plus Earpiece Speaker Replacement: шаг 7, изображение 1 из 3 iPhone 6 Plus Earpiece Speaker Replacement: шаг 7, изображение 2 из 3 iPhone 6 Plus Earpiece Speaker Replacement: шаг 7, изображение 3 из 3
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  8. iPhone 6 Plus Earpiece Speaker Replacement: шаг 8, изображение 1 из 2 iPhone 6 Plus Earpiece Speaker Replacement: шаг 8, изображение 2 из 2
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  9. iPhone 6 Plus Earpiece Speaker Replacement: шаг 9, изображение 1 из 1
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  10. iPhone 6 Plus Earpiece Speaker Replacement: шаг 10, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Plus Earpiece Speaker Replacement: шаг 11, изображение 1 из 1
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Plus Earpiece Speaker Replacement: шаг 12, изображение 1 из 1
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  13. iPhone 6 Plus Earpiece Speaker Replacement: шаг 13, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Plus Earpiece Speaker Replacement: шаг 14, изображение 1 из 2 iPhone 6 Plus Earpiece Speaker Replacement: шаг 14, изображение 2 из 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  15. iPhone 6 Plus Earpiece Speaker Replacement: шаг 15, изображение 1 из 2 iPhone 6 Plus Earpiece Speaker Replacement: шаг 15, изображение 2 из 2
    • Disconnect the home button cable connector.
  16. iPhone 6 Plus Earpiece Speaker Replacement: шаг 16, изображение 1 из 2 iPhone 6 Plus Earpiece Speaker Replacement: шаг 16, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Plus Earpiece Speaker Replacement: шаг 17, изображение 1 из 2 iPhone 6 Plus Earpiece Speaker Replacement: шаг 17, изображение 2 из 2
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Plus Earpiece Speaker Replacement: шаг 18, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Plus Earpiece Speaker Replacement, Earpiece Speaker: шаг 19, изображение 1 из 1
    • Remove the following Phillips screws securing the upper component bracket:
    • One 1.5 mm screw
    • Two 2.3 mm screws
  20. iPhone 6 Plus Earpiece Speaker Replacement: шаг 20, изображение 1 из 1
    • Lift and remove the earpiece bracket from the display assembly.
  21. iPhone 6 Plus Earpiece Speaker Replacement: шаг 21, изображение 1 из 1
    • Use a the flat end of a spudger to pry up the front-facing camera and display cables, and gently push them aside.
  22. iPhone 6 Plus Earpiece Speaker Replacement: шаг 22, изображение 1 из 1
    • Use a pair of tweezers to firmly grasp and remove the earpiece speaker from the display assembly.
Заключение
91 участников успешно повторили данное руководство.
7 Комментариев
Dropped my iphone and the speaker stopped working.
Expected that it was a connector that was lose.
Used this guide to fix it.... Thanks :)
henriklotstrand - Ответить
My son was chewing on my phone and the speaker was real quiet afterwards. I purchased your product above and installed but nothing changed. Not sure what else it could be, don't want to purchase a 100$ display only to have that not fix the issue either. And of course since I've already opened it Apple sent it back to me :D
Jacob Carrillo - Ответить
After dropping my iPhone from the car, the speaker stopped working. Thankfully using this guide I was able to reseat the connector and all was good again. Make sure the four cable are attached properly to the board when reassembling as I had to take the protective covers back off again and reseat them.
Overall I feel confident that I would be able to do it again.
On a separate note I would highly recommend a decent precision set to carry out any repairs on these small devices. The screws are tiny and magnetised tools are a must.
Thanks iFixit!
Sam Colbear - Ответить
phone worse off, smh, well i did as it said, i even bought all the tools from them that i needed, now my phone stuck on apple logo, did reset holding power and home button, went back in disconnected reconnect display connection and power cycled disconnecting battery connector, and still stuck on apple logo. followed everything, was careful, dont know if i went wrong, or what
tony ny - Ответить
UPDATE been 20 min finally went to home screen but charging port not working, tried 3 different usb cords, will keep u updated while i try figure this $@$* out
tony ny - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 40
За всё время: 76,758
