Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prereq only for rear case.
Выберете то, что вам нужно
Remove the two 3.3 mm Phillips #00 screws securing the metal bracket to the Lightning connector assembly.
Use the flat edge of a spudger to pry the antenna connector cable up off its socket on the Lightning connector assembly.
Remove the following Phillips #00 screws securing the Lightning connector assembly to the rear case:
Two 3.2 mm screws
One 3.8 mm screw
Two 1.7 mm screws
Two 1.5 mm screws
Two 1.4 mm screws
Use a pair of tweezers to grasp the plastic clip that is situated to the right of the headphone jack and remove it from the iPhone.
2 участников успешно повторили данное руководство.
