iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement
Выберете то, что вам нужно
Видео обзор
  1. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Anti-Clamp instructions: шаг 2, изображение 1 из 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Anti-Clamp instructions: шаг 2, изображение 2 из 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Anti-Clamp instructions: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 3, изображение 1 из 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 3, изображение 2 из 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 3, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Front Panel Assembly: шаг 4, изображение 1 из 1
    • Use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 5, изображение 1 из 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 6, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 6, изображение 2 из 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 7, изображение 1 из 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 7, изображение 2 из 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 7, изображение 3 из 3
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  8. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 8, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 8, изображение 2 из 2
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  9. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 9, изображение 1 из 1
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  10. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 10, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 11, изображение 1 из 1
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 12, изображение 1 из 1
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  13. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 13, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 14, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 14, изображение 2 из 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  15. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 15, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 15, изображение 2 из 2
    • Disconnect the home button cable connector.
  16. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 16, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 16, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 17, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 17, изображение 2 из 2
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 18, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Disconnect Charge Port: шаг 19, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Disconnect Charge Port: шаг 19, изображение 2 из 2
    • Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
  20. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 20, изображение 1 из 1
    • Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
  21. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 21, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 21, изображение 2 из 2
    • Grasp the interconnect antenna cable with a pair of tweezers and carefully de-route it from its channel on the vibrator assembly.
  22. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 22, изображение 1 из 1
    • Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
  23. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 23, изображение 1 из 1
    • Remove the vibrator from the iPhone.
  24. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Speaker: шаг 24, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Speaker: шаг 24, изображение 2 из 2
    • Grasp the antenna connector with a pair of tweezers and carefully begin de-routing it from its channel on the speaker.
  25. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 25, изображение 1 из 1
    • To fully de-route the antenna connector, you may need to gently pull back the metal clip securing it to the speaker assembly.
  26. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 26, изображение 1 из 1
    • Remove the following screws securing the speaker to the rear case:
    • One 2.3 mm Phillips #00 screw
    • One 2.8 mm Phillips #00 screw
  27. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 27, изображение 1 из 1
    • Lift and remove the speaker out of the iPhone.
  28. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Lightning Connector Assembly: шаг 28, изображение 1 из 1
    • Remove the two 3.3 mm Phillips #00 screws securing the metal bracket to the Lightning connector assembly.
  29. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 29, изображение 1 из 1
    • Use a pair of tweezers to lift and remove the metal bracket out of the iPhone.
  30. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 30, изображение 1 из 1
    • Use the flat edge of a spudger to pry the antenna connector cable up off its socket on the Lightning connector assembly.
  31. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 31, изображение 1 из 1
    • Lift and remove the antenna connector out of the iPhone.
  32. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 32, изображение 1 из 1
    • Remove the following Phillips #00 screws securing the Lightning connector assembly to the rear case:
    • Two 3.2 mm screws
    • One 3.8 mm screw
    • Two 1.7 mm screws
    • Two 1.5 mm screws
    • Two 1.4 mm screws
  33. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 33, изображение 1 из 1
    • Use a pair of tweezers to grasp the plastic clip that is situated to the right of the headphone jack and remove it from the iPhone.
  34. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement, Lightning Connector and Headphone Jack Cable: шаг 34, изображение 1 из 1
    • The next step requires peeling the Lightning connector and headphone jack cable that is affixed to the inside of the rear case with mild adhesive. We highly recommend using an iOpener to heat the lower backside of the rear case.
  35. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 35, изображение 1 из 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 35, изображение 2 из 3 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 35, изображение 3 из 3
    • Use an opening pick to slowly separate the Lightning connector and headphone jack cable from the rear case.
    • If the adhesive feels hard to slice, apply additional heat and try again.
    • Carefully work the pick down the right side of the Lightning connector and headphone jack cable, making sure to stop right as you hit the bottom.
  36. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 36, изображение 1 из 1
    • Insert the pick underneath the right bottom corner of the Lightning connector and headphone jack cable.
  37. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 37, изображение 1 из 2 iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 37, изображение 2 из 2
    • Run the opening pick across the top of Lightning connector and headphone jack cable to loosen the adhesive securing it to the rear case.
  38. iPhone 6 Plus Lightning Connector and Headphone Jack Cable Replacement: шаг 38, изображение 1 из 1
    • Lift and remove the Lightning connector and headphone jack cable out of the iPhone.
    • Before installing or replacing the Lightning connector assembly:
    • Use a plastic tool to scour any bits of adhesive residue from the rear case behind the cable.
    • Compare your replacement part to the original and note any differences. You may find a rubber gasket adhered to the old headphone jack, which should be transferred to the new part if needed.
    • Test fit your replacement part, and then peel off any protective plastic films or liners before installing.
Заключение
147 участников успешно повторили данное руководство.
25 Комментариев
I did this tonight, took about 45 min. I used my iFixit tool kit to all the work.
When putting it back together I had an issue with my screen going all "white lines", turns out it was just a loose connection on the digitizer cable, I lifted it and placed it again and all is good with the world.
I had to replace the assembly because I was getting feedback when making calls with headphones and no voice at all with headphones if the phone was plugged into power. Now I can do both.
Thanks so much iFixit for making this possible.
rianrachel - Ответить
After fixing my headset jack successfully, people could not hear me clearly on the mic. I took it apart again today. The clip that holds the mic in place, next to the jack, had been put down too tight to the mic, which kept it from moving enough to pick sound up clearly -- everything was muddied. I only had to pull the case open a little, unscrew the mic assembly to loosen it, wiggle it back a bit, move the mic a little to align it better with the hole, and then tighten it back down. It works beautifully now and everyone says I sound better than ever. A really easy fix, but it could have been avoided if there were instructions on putting everything back together or at least tips for little things like this.
maztec - Ответить
My iphone stuck into headphone,what can i do to fix it?please help me as soon as possible
Tannaz pourian - Ответить
Hi @Tannaz pourian
If you are stuck on headphone mode first thing you can do is a quick fix if it works for you. You first turn off your iphone and with a gentle hand you can pull out any dirt or particals inside your headphone jack with a pin then clean it with a cotton bud with a little acitone or alcohol ( Don’t use too much of alcohol only little would be fine otherwise it could damage you display if it gets into your phone). Then after completing this process let it dry for a while and turn on your phone. I hope it works for you:) orthewise you have to replace your whole cc flex pannel. Good luck
Rishabh Madaan -
I recently replaced the headphone jack but when I tried it out after successfully replacing it, the headphones still gave a crackling sound. Less than before but still very noticeable. Anyone have any suggestions to fix this issue?
collinwanat - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 27
За последние 30 дней: 118
За всё время: 161,846
