Введение
Prereq only.
Выберете то, что вам нужно
Remove the single 2.8 mm Phillips #00 screw securing the plastic clip to the logic board.
Remove the single 1.3 mm Phillips #00 screw recessed against the top of the rear case.
Use a pair of tweezers to firmly grasp the plastic clip and remove it from the iPhone.
Remove the single 1.6 mm Phillips #00 screw securing the antenna clip to the rear case.
Carefully grasp the antenna clip with a pair of tweezers and remove it from the iPhone.
