Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to replace the speaker.
  1. Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
    • Close the handle on the iSclack, opening the suction cup jaws.
    • Place the bottom of your iPhone in between the suction cups.
    • Position the iSclack's upper suction cup against the display, near the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  2. Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 7.
  3. If you don't have an iSclack, use a single suction cup to lift the front panel:
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  4. While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  5. Pull the plastic nub to release the vacuum seal on the suction cup. Remove the suction cup from the display assembly.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  6. Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone. Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  7. Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book. During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. Remove the following Phillips screws from the battery connector bracket:
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  9. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  10. Remove the metal battery connector bracket from the iPhone.
    • Remove the metal battery connector bracket from the iPhone.
  11. Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  13. Remove the front panel assembly cable bracket from the logic board.
    • Remove the front panel assembly cable bracket from the logic board.
  14. In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board. While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  15. Disconnect the home button cable connector. Disconnect the home button cable connector.
    • Disconnect the home button cable connector.
  16. Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Use a plastic opening tool to disconnect the display data cable connector.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. Finally, disconnect the digitizer cable connector. When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. Remove the front panel assembly from the rear case.
    • Remove the front panel assembly from the rear case.
  19. Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger. Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
    • Pry the vibrator connector cable up from its socket on the logic board with the flat end of a spudger.
  20. Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
    • Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
  21. Grasp the interconnect antenna cable with a pair of tweezers and carefully de-route it from its channel on the vibrator assembly. Grasp the interconnect antenna cable with a pair of tweezers and carefully de-route it from its channel on the vibrator assembly.
    • Grasp the interconnect antenna cable with a pair of tweezers and carefully de-route it from its channel on the vibrator assembly.
  22. Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
    • Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
  23. Remove the vibrator from the iPhone.
    • Remove the vibrator from the iPhone.
  24. Grasp the antenna connector with a pair of tweezers and carefully begin de-routing it from its channel on the speaker. Grasp the antenna connector with a pair of tweezers and carefully begin de-routing it from its channel on the speaker.
    • Grasp the antenna connector with a pair of tweezers and carefully begin de-routing it from its channel on the speaker.
  25. To fully de-route the antenna connector, you may need to gently pull back the metal clip securing it to the speaker assembly.
    • To fully de-route the antenna connector, you may need to gently pull back the metal clip securing it to the speaker assembly.
  26. Remove the following screws securing the speaker to the rear case:
    • Remove the following screws securing the speaker to the rear case:
    • One 2.3 mm Phillips #00 screw
    • One 2.8 mm Phillips #00 screw
  27. Lift and remove the speaker out of the iPhone.
    • Lift and remove the speaker out of the iPhone.
Заключение
43 участников успешно повторили данное руководство.
Комментариев: 5
Hi there where can I buy that small plastic blue tool you have shown to be using in the pictures above?
Jason D'souza - Ответить
All the tools used in this guide are linked in the Tools section at the top. The one you're looking for can be purchased here—it has been redesigned since this guide was written, so it looks slightly different from what you see in these photos.
Jeff Suovanen -
Changed out one of these today but the sound did not improve at all and it still sounds awful. Is there some kind of membrane between the speaker and the bottom of the phone where the holes are? Since the speaker is brand new it has to be something else making this distorted sound.
skulasonarni - Ответить
The loudspeaker is with distortion, and even changing it, it does not improve. Any hint what may be the problem? I got 1 iphone 6 and one 6+ with the same problem.
rmguimar - Ответить
Hi, why is it necessary to remove the screen completely ?
WH0Y0USH00TIN - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 23
За последние 30 дней: 146
За всё время: 40,284
