Введение
Use this guide to replace the speaker.
Выберете то, что вам нужно
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
Close the handle on the iSclack, opening the suction cup jaws.
Place the bottom of your iPhone in between the suction cups.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
Peel the two suction cups off your iPhone.
Skip the next three steps and continue on to Step 7.
If you don't have an iSclack, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following Phillips screws from the battery connector bracket:
One 2.3 mm screw
One 3.1 mm screw
Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.5 mm screw
One 2.9 mm screw
While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
Grasp the interconnect antenna cable with a pair of tweezers and carefully de-route it from its channel on the vibrator assembly.
Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
Grasp the antenna connector with a pair of tweezers and carefully begin de-routing it from its channel on the speaker.
Remove the following screws securing the speaker to the rear case:
One 2.3 mm Phillips #00 screw
One 2.8 mm Phillips #00 screw
46 участников успешно повторили данное руководство.
5 Comments
Hi there where can I buy that small plastic blue tool you have shown to be using in the pictures above?
All the tools used in this guide are linked in the Tools section at the top. The one you're looking for can be purchased here—it has been redesigned since this guide was written, so it looks slightly different from what you see in these photos.
Changed out one of these today but the sound did not improve at all and it still sounds awful. Is there some kind of membrane between the speaker and the bottom of the phone where the holes are? Since the speaker is brand new it has to be something else making this distorted sound.
Hi, why is it necessary to remove the screen completely ?
