Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Prereq for display assembly.
Запчасти
Детали не указаны.
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 6 Plus that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip down two steps.
    • If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
    • Close the handle on the iSclack, opening the suction cup jaws.
    • Place the bottom of your iPhone in between the suction cups.
    • Position the iSclack's upper suction cup against the display, near the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
    • If your display or back glass is badly cracked, covering it with a layer of clear packing tape may help the suction cups adhere. The iSclack also includes two pieces of tape for this purpose.
  1. Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone enough to separate the pieces, but not enough to damage any of the display cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 7.
Заключение
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 510
