Введение
Spotty signal on wi-fi? You may need to replace the upper wi-fi antenna in your iPhone 6.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long Pentalobe screws next to the Lightning connector.
If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6.
Close the handle on the iSclack, opening the suction-cup jaws.
Place the bottom of your iPhone in between the suction cups.
Position the iSclack's upper suction cup against the display, just above (but not covering) the home button.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the display cables.
Peel the two suction cups off your iPhone.
Skip the next three steps and continue on to Step 8.
If you don't have an iSclack, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
Remove the front panel assembly from the rear case.
Remove the following Phillips screws from the upper cable bracket:
One 2.9 mm screw
One 2.2 mm screw
Remove the following four Phillips screws from the Wi-Fi antenna:
One 1.5 mm screw
One 1.4 mm screw
Two 2.1 mm screws
187 участников успешно повторили данное руководство.
Комментариев: 21
If your iphone 6 has bad wifi signal, replacing this unit alone won't fix the problem. I had to replace the cable (PN: T308S) connecting this unit to the logic board. I bought it on eBay. It came with completely differnt part number, but worked perfectly
Yeah khanhag005 is right, replacing this piece alone most likely won't do anything to help your WiFi / Bluetooth.
Replace the WiFi / Bluetooth cable if your WiFi or Bluetooth isn't working or if your WiFi button in greyed out. I bought mine on eBay for less than $3 and it took me less than an hour to do using the guide iPhone 6 Antenna Flex Cable Replacement
Referring to the Antenna Flex Cable Replacement post comment on Aug30/31 post by Andy, 85 was referencing the grey out probably can't be fixed by replacing the cable neither
wonder if anyone has the actually grey out wifi issue and know which part to order?
Walter A -
I had an issue with my iPhone with poor WiFi reception and most of the time couldn't connect to WiFi at all. If the WiFi signal from a router was strong, that was the only time I could connect. The Apple store ran their diagnostics and told me there was no fault detected and the option was to pay $429 AUD for a replacement phone so I did some fault finding myself. After reinstalling the firmware through a DFU restore and reinstalling the software to rule out both those contenders it was pretty certain it was a hardware issue.
I replaced the WiFi antenna and also the antenna flex cable while I was in there. The issue is resolved and phone is functioning perfectly. I cannot say which part solved the issue but figured it was worth changing both out at the same time. The repair guide was spot on and super easy to follow, parts supplied from iFIXIT were good quality and did the job. Overall coast was just over $50 AUD including tools and shipping. Thank you!
Bought the new antenna and the required tools from amazing and followed this guide to the last detail. I was successfully able to replace my antenna and solve my wifi and gps issues. Thanks a lot.
