Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prereq for display assembly.
Выберете то, что вам нужно
If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6.
Close the handle on the iSclack, opening the suction-cup jaws.
Place the bottom of your iPhone in between the suction cups.
Position the iSclack's upper suction cup against the display, just above (but not covering) the home button.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the display cables.
Peel the two suction cups off your iPhone.
Skip the next three steps and continue on to Step 8.
2 участников успешно повторили данное руководство.
