Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prereq only; disconnect the battery before anything else.
Выберете то, что вам нужно
Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
Use the edge of a spudger to slice through the adhesive on either side of the phone.
Remove the following screws from the battery connector bracket:
One 3.0 mm Phillips #00 screw
One 2.3 mm Phillips #00 screw
Use the flat end of a spudger to disconnect the battery connector from the logic board.
Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
Еще один человек закончил это руководство.
3 Комментариев
While replacing a charging port on the 6s I realized that the battery didn't seem to stay seated. It also won't charge past a certain percentage. Anyone run into this?
BE FOREWARNED: I used this guide and ended up breaking one of the cables to my display on step 8. Now my home button, camera and speaker don’t work and I have to spend 80 dollars for a new lcd panel.
The featured guide (not this one) shows how to completely detach the screen cables so this won’t happen. Do a quick search and take a look before possibly breaking your phone on step 8. Fully detaching the panel would have prevented this issue
DO NOT USE THIS GUIDE: It is not complete. I ended up having to goto the store and pay $250 dollars to get my I phone fixed after breaking it with these incomplete directions.
This is a more complete guide use this one: iPhone 6s Battery Replacement
