Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
Use the edge of a spudger to slice through the adhesive on either side of the phone.
THESE INSTRUCTION / GUIDE IS NOT COMPLETE. I broke my phone and ended up with $250 in repairs at the local cell phone store at this step. You need to detach the display completely instead of prop it up against a box. It is very likely your cables will tear at this step if you don’t completely detach the display
Remove the following screws from the battery connector bracket:
One 3.0 mm Phillips #00 screw
One 2.3 mm Phillips #00 screw
Use the flat end of a spudger to disconnect the battery connector from the logic board.
Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery.
Grab the ends of the two adhesive strips and hold them together. Try to keep the strips flat and wide.
Slowly and gently pull the two strips up and away from the phone.
The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case.
Remove the battery from the rear case.
75 участников успешно повторили данное руководство.
11 Комментариев
I need to buy the 6s replacement battery itself as well as the tools. Do you sell that as well as the display?
i remember i get my battery repair kit and adhesive for less than 25$ from this seller on amazon https://www.amazon.com/dp/B01LKN9AUG
exdany9 -
Please do a video. Lets see how fast you guys can change the 6s battery.
What if I didn't get all the adhesive out from under the battery?!
Very nice and helped me a lot. Thank you.
Success. I got one adhesive strip to come out in one piece. The 2nd one snapped in half. I had to do the pry-of-shame, but once I could see the adhesive underneath the battery, I was able to grab it with the angled tweezers, and pull the rest of it out. Wow it’s a lot easier to remove the battery if you get both adhesive strips out in one piece each! I left the screen attached during the battery replacement, so I only removed the batter connector cover. Helps to have a 2nd person hold the screen so you don’t damage the connectors.
