iPhone 6s Plus Screen Replacement
Выберете то, что вам нужно
Видео обзор
  1. iPhone 6s Plus Screen Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. iPhone 6s Plus Screen Replacement, Taping Over The Display: шаг 2, изображение 1 из 3 iPhone 6s Plus Screen Replacement, Taping Over The Display: шаг 2, изображение 2 из 3 iPhone 6s Plus Screen Replacement, Taping Over The Display: шаг 2, изображение 3 из 3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  3. iPhone 6s Plus Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 6s Plus Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 6s Plus Screen Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 6s Plus Screen Replacement: шаг 4, изображение 1 из 3 iPhone 6s Plus Screen Replacement: шаг 4, изображение 2 из 3 iPhone 6s Plus Screen Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  5. iPhone 6s Plus Screen Replacement, Opening Procedure: шаг 5, изображение 1 из 1
    Anti-Clamp
    $24.95
    Купить
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  6. iPhone 6s Plus Screen Replacement: шаг 6, изображение 1 из 1
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  7. iPhone 6s Plus Screen Replacement: шаг 7, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 7, изображение 2 из 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  8. iPhone 6s Plus Screen Replacement: шаг 8, изображение 1 из 3 iPhone 6s Plus Screen Replacement: шаг 8, изображение 2 из 3 iPhone 6s Plus Screen Replacement: шаг 8, изображение 3 из 3
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  9. iPhone 6s Plus Screen Replacement: шаг 9, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 9, изображение 2 из 2
    • Twist the spudger to widen the gap between the front panel and the rear case.
  10. iPhone 6s Plus Screen Replacement: шаг 10, изображение 1 из 3 iPhone 6s Plus Screen Replacement: шаг 10, изображение 2 из 3 iPhone 6s Plus Screen Replacement: шаг 10, изображение 3 из 3
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  11. iPhone 6s Plus Screen Replacement: шаг 11, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 11, изображение 2 из 2
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  12. iPhone 6s Plus Screen Replacement: шаг 12, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 12, изображение 2 из 2
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  13. iPhone 6s Plus Screen Replacement: шаг 13, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 13, изображение 2 из 2
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  14. iPhone 6s Plus Screen Replacement: шаг 14, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 14, изображение 2 из 2
    • Pull up on the small nub on the suction cup to remove it from the display.
  15. iPhone 6s Plus Screen Replacement: шаг 15, изображение 1 из 3 iPhone 6s Plus Screen Replacement: шаг 15, изображение 2 из 3 iPhone 6s Plus Screen Replacement: шаг 15, изображение 3 из 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  16. iPhone 6s Plus Screen Replacement, Battery Connector: шаг 16, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    Купить
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  17. iPhone 6s Plus Screen Replacement: шаг 17, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 17, изображение 2 из 2
    • Remove the battery connector bracket.
  18. iPhone 6s Plus Screen Replacement: шаг 18, изображение 1 из 3 iPhone 6s Plus Screen Replacement: шаг 18, изображение 2 из 3 iPhone 6s Plus Screen Replacement: шаг 18, изображение 3 из 3
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  19. iPhone 6s Plus Screen Replacement: шаг 19, изображение 1 из 3 iPhone 6s Plus Screen Replacement: шаг 19, изображение 2 из 3 iPhone 6s Plus Screen Replacement: шаг 19, изображение 3 из 3
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  20. iPhone 6s Plus Screen Replacement, Display Assembly: шаг 20, изображение 1 из 1
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  21. iPhone 6s Plus Screen Replacement: шаг 21, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 21, изображение 2 из 2
    • Remove the display cable bracket.
  22. iPhone 6s Plus Screen Replacement: шаг 22, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 22, изображение 2 из 2
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  23. iPhone 6s Plus Screen Replacement: шаг 23, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 23, изображение 2 из 2
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  24. iPhone 6s Plus Screen Replacement: шаг 24, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 24, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  25. iPhone 6s Plus Screen Replacement: шаг 25, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 25, изображение 2 из 2
  26. iPhone 6s Plus Screen Replacement, Home Button Assembly: шаг 26, изображение 1 из 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
  27. iPhone 6s Plus Screen Replacement: шаг 27, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 27, изображение 2 из 2
    • Remove the home button bracket.
  28. iPhone 6s Plus Screen Replacement: шаг 28, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 28, изображение 2 из 2
    • Use the pointed tip of a spudger to disconnect the home button cable from its connector on the display assembly.
  29. iPhone 6s Plus Screen Replacement: шаг 29, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 29, изображение 2 из 2
    iOpener
    $19.99
    Купить
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
  30. iPhone 6s Plus Screen Replacement: шаг 30, изображение 1 из 3 iPhone 6s Plus Screen Replacement: шаг 30, изображение 2 из 3 iPhone 6s Plus Screen Replacement: шаг 30, изображение 3 из 3
    • Use the pointed end of a spudger to pry the lightly-adhered home button flex cable off the display assembly.
  31. iPhone 6s Plus Screen Replacement: шаг 31, изображение 1 из 2 iPhone 6s Plus Screen Replacement: шаг 31, изображение 2 из 2
    • Remove the home button assembly.
Заключение
582 участников успешно повторили данное руководство.
Jeff Suovanen
Участник с: 08/06/13
428 098 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 817 руководств
73 Комментариев
What do you do about the 3D touch?
Brayden Weller - Ответить
The 3D Touch sensor should be integrated into the replacement part that you buy. If you check out our display teardown you can see that it's embedded two layers deep in the display assembly, so there are no discrete parts you need to worry about.
Evan Noronha -
And if you replace the home button with a new one the finger sensor usually don't work again
Michael Kimmel - Ответить
This is because the home button that originally comes with the phone is "married" is married to the phone. This connection can never be returned if home button is broken or replaced. That in turn makes touch id not work because its not coded to the phone. Apple can not remarry phones in case anybody was wondering. Take good care of your home button
massacre13581 -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 23
За последние 7 дней: 175
За последние 30 дней: 766
За всё время: 429,020
