Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Follow the steps in this guide to replace the power button cover in your iPhone 6s Plus. This guide is only to replace the external power button cover, not the physical switch. If the button cover on your phone is undamaged but the power button does not work, you can follow this guide to replace the power switch underneath the button cover.
Выберете то, что вам нужно
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
Инструмент, используемый на этом этапе:Anti-Clamp$24.95
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
The safest place to pry from is the notch in the front panel above the headphone jack.
While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
Insert the flat tip of the spudger under the right edge of the display.
Slide the spudger up the right side.
Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
Remove the following Phillips screws over the camera bracket:
One 1.9 mm screw
One 2.4 mm screw
Insert the flat end of the spudger between the iSight camera and rear casing.
Gently pry the camera out from its housing.
Insert a SIM eject tool into the hole in the SIM tray.
Press to eject the SIM tray.
Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
Remove the two 2.7 mm Phillips screws securing the audio control cable bracket to the logic board.
Disconnect the audio control cable by prying its connector straight up from its socket on the logic board.
Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board.
Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board.
Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board.
Deroute the antenna cable from the two clips on the right edge of the logic board.
Инструмент, используемый на этом этапе:Standoff Screwdriver for iPhones$5.49
Remove the following screws:
One 1.3 mm Phillips screw
One 2.6 mm Phillips screw
One 2.2 mm standoff screw
Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery.
Continue derouting the cellular antenna cable from the second and third logic board clips.
Use the pointed tip of a spudger to gently pry the cellular antenna cable from the middle logic board clip.
Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board.
Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
Remove the following four Phillips screws:
Three 2.0 mm screws holding the power button bracket in place
One 1.3 mm Phillips screw over the flash and microphone bracket
Use the pointed end of a spudger to lift the flash out of its housing in the rear case.
Use the flat end of a spudger to peel the power button flex cable off the rear case.
Insert the tip of a spudger underneath the microphone portion of the flex cable and gently pry it off of the rear case.
Slide an opening pick underneath the power button flex cable to pry the cable off the rear case.
Gently nudge the power button cover out of its slot in the rear case.
9 участников успешно повторили данное руководство.
Один комментарий
Hi,
I have done all the process, I have replaced the power button, but this does not fix the “no clicking” button issue.
Should I replace the power flat cable too? Or could it be related about how power button is inserted in the hole?
My power button flat is “clicking” if I try it with my nail, but I don’t know if this is enought clicking or it has got too much use..
