Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Prerequisite guide only! Speaker module replacement for the iPhone 6s Plus. Updated version which contains photos that have the logic board intact.
Выберете то, что вам нужно
Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board.
Use the point of a spudger to pry up and disconnect the Lightning connector cable from the logic board.
Remove the three Phillips screws securing the Lightning connector bracket:
Two 3.5 mm screws
One 2.7 mm screw
Remove the bracket.
Use the point of a spudger to pry up and disconnect the antenna cable from the Lightning connector assembly.
Use the point of a spudger to pry up and disconnect the antenna cable from the top of the logic board.
Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable free it from the retaining clips.
Remove the six Phillips screws securing the speaker to the rear case:
One 2.5 mm screw
Two 2.7 mm screws
One 1.5 mm screw
One 1.7 mm screw
One 2.6 mm screw securing the speaker to the bottom edge of the rear case.
Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
Pry gently to loosen the speaker module.
Once the module is loose, lift and remove the speaker module and the attached antenna cable from the phone.
