Отремонтируйте ваше устройство
Обучение ремонту
Магазин
  1. Этот шаг не переведен. Помогите перевести
    Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  2. Этот шаг не переведен. Помогите перевести
    Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  3. Этот шаг не переведен. Помогите перевести
    Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  4. Этот шаг не переведен. Помогите перевести
    The safest place to pry from is the notch in the front panel above the headphone jack. While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack. While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  5. Этот шаг не переведен. Помогите перевести
    Twist the spudger to widen the gap between the front panel and the rear case. Twist the spudger to widen the gap between the front panel and the rear case.
    • Twist the spudger to widen the gap between the front panel and the rear case.
  6. Этот шаг не переведен. Помогите перевести
    While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display. While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display. While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  7. Этот шаг не переведен. Помогите перевести
    Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case. Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  8. Этот шаг не переведен. Помогите перевести
    Insert the flat tip of the spudger under the right edge of the display. Slide the spudger up the right side.
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  9. Этот шаг не переведен. Помогите перевести
    Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone. Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  10. Этот шаг не переведен. Помогите перевести
    Pull up on the small nub on the suction cup to remove it from the display. Pull up on the small nub on the suction cup to remove it from the display.
    • Pull up on the small nub on the suction cup to remove it from the display.
  11. Этот шаг не переведен. Помогите перевести
    Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone. Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  12. Этот шаг не переведен. Помогите перевести
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  13. Этот шаг не переведен. Помогите перевести
    Remove the battery connector bracket. Remove the battery connector bracket.
    • Remove the battery connector bracket.
  14. Этот шаг не переведен. Помогите перевести
    Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board. Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board. Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  15. Этот шаг не переведен. Помогите перевести
    Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it. Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it. Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  16. Этот шаг не переведен. Помогите перевести
    Remove the following Phillips screws:
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  17. Этот шаг не переведен. Помогите перевести
    Remove the display cable bracket. Remove the display cable bracket.
    • Remove the display cable bracket.
  18. Этот шаг не переведен. Помогите перевести
    Be careful to only pry up on the connector itself and not the socket on the logic board. Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  19. Этот шаг не переведен. Помогите перевести
    Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board. When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  20. Этот шаг не переведен. Помогите перевести
    Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  21. Этот шаг не переведен. Помогите перевести
    Remove the display assembly. During reassembly, pause here if you wish to replace the adhesive around the edges of the display.
  22. Этот шаг не переведен. Помогите перевести
    Peel up any tape covering the iSight camera bracket screws. Peel up any tape covering the iSight camera bracket screws. Peel up any tape covering the iSight camera bracket screws.
    • Peel up any tape covering the iSight camera bracket screws.
  23. Этот шаг не переведен. Помогите перевести
    Remove the following Phillips screws over the camera bracket:
    • Remove the following Phillips screws over the camera bracket:
    • One 1.9 mm screw
    • One 2.4 mm screw
  24. Этот шаг не переведен. Помогите перевести
    Remove the iSight camera bracket. Remove the iSight camera bracket.
    • Remove the iSight camera bracket.
  25. Этот шаг не переведен. Помогите перевести
    Disconnect the iSight camera connector from its socket on the logic board. Be sure to pry up only the connector and not the socket on the logic board.
    • Disconnect the iSight camera connector from its socket on the logic board.
    • Be sure to pry up only the connector and not the socket on the logic board.
  26. Этот шаг не переведен. Помогите перевести
    Insert the flat end of the spudger between the iSight camera and rear casing. Gently pry the camera out from its housing.
    • Insert the flat end of the spudger between the iSight camera and rear casing.
    • Gently pry the camera out from its housing.
  27. Этот шаг не переведен. Помогите перевести
    Remove the iSight camera. Remove the iSight camera.
    • Remove the iSight camera.
  28. Этот шаг не переведен. Помогите перевести
    Insert a SIM eject tool into the hole in the SIM tray. Press to eject the SIM tray.
    • Insert a SIM eject tool into the hole in the SIM tray.
    • Press to eject the SIM tray.
  29. Этот шаг не переведен. Помогите перевести
    Remove the SIM tray.
    • Remove the SIM tray.
    • When reinserting the SIM tray, be sure to orient the tray such that the SIM eject hole is on the bottom.
  30. Этот шаг не переведен. Помогите перевести
    Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
    • Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
  31. Этот шаг не переведен. Помогите перевести
    Remove the NFC bracket. Remove the NFC bracket.
    • Remove the NFC bracket.
  32. Этот шаг не переведен. Помогите перевести
    Remove the two 2.7 mm Phillips screws securing the audio control cable bracket to the logic board.
    • Remove the two 2.7 mm Phillips screws securing the audio control cable bracket to the logic board.
  33. Этот шаг не переведен. Помогите перевести
    Remove the audio control cable bracket. Remove the audio control cable bracket.
    • Remove the audio control cable bracket.
  34. Этот шаг не переведен. Помогите перевести
    Disconnect the audio control cable by prying its connector straight up from its socket on the logic board. Disconnect the audio control cable by prying its connector straight up from its socket on the logic board.
    • Disconnect the audio control cable by prying its connector straight up from its socket on the logic board.
  35. Этот шаг не переведен. Помогите перевести
    Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board. Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board.
    • Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board.
  36. Этот шаг не переведен. Помогите перевести
    Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board. Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board.
    • Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board.
  37. Этот шаг не переведен. Помогите перевести
    Disconnect the power button flex cable from its socket on the logic board. Disconnect the power button flex cable from its socket on the logic board.
    • Disconnect the power button flex cable from its socket on the logic board.
  38. Этот шаг не переведен. Помогите перевести
    Disconnect the Lightning connector interconnect antenna cable by prying it up from the logic board. Disconnect the Lightning connector interconnect antenna cable by prying it up from the logic board.
    • Disconnect the Lightning connector interconnect antenna cable by prying it up from the logic board.
  39. Этот шаг не переведен. Помогите перевести
    Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board. Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board.
    • Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board.
  40. Этот шаг не переведен. Помогите перевести
    Deroute the antenna cable from the two clips on the right edge of the logic board. Deroute the antenna cable from the two clips on the right edge of the logic board. Deroute the antenna cable from the two clips on the right edge of the logic board.
    • Deroute the antenna cable from the two clips on the right edge of the logic board.
  41. Этот шаг не переведен. Помогите перевести
    • Remove the following screws:
    • One 1.3 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 2.2 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  42. Этот шаг не переведен. Помогите перевести
    Remove the bracket. Remove the bracket.
    • Remove the bracket.
  43. Этот шаг не переведен. Помогите перевести
    Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery. Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery.
    • Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery.
  44. Этот шаг не переведен. Помогите перевести
    Continue derouting the cellular antenna cable from the second and third logic board clips. Use the pointed tip of a spudger to gently pry the cellular antenna cable from the middle logic board clip. Don't try to remove it by pulling on the cable, as it will tear easily.
    • Continue derouting the cellular antenna cable from the second and third logic board clips.
    • Use the pointed tip of a spudger to gently pry the cellular antenna cable from the middle logic board clip.
    • Don't try to remove it by pulling on the cable, as it will tear easily.
    • In order for the cable to reach its socket on the logic board, you must route it above the logic board and underneath the audio control flex cable, as shown in the first photo.
  45. Этот шаг не переведен. Помогите перевести
    Remove the final 2.0 mm Phillips screw directly below the SIM card reader.
    • Remove the final 2.0 mm Phillips screw directly below the SIM card reader.
  46. Этот шаг не переведен. Помогите перевести
    Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector. Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector. Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
    • Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
  47. Этот шаг не переведен. Помогите перевести
    Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board. Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board. Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board.
    • Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board.
    • Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board.
  48. Этот шаг не переведен. Помогите перевести
    Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone. Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
    • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
    • Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
  49. Этот шаг не переведен. Помогите перевести
    Remove the logic board.
    • Remove the logic board.
  50. Этот шаг не переведен. Помогите перевести
    Remove the sticker over the third screw holding the cellular antenna in place. Remove the sticker over the third screw holding the cellular antenna in place.
    • Remove the sticker over the third screw holding the cellular antenna in place.
  51. Этот шаг не переведен. Помогите перевести
    Remove the following three Phillips screws holding the cellular antenna in place:
    • Remove the following three Phillips screws holding the cellular antenna in place:
    • One 2.7 mm screw
    • One 1.7 mm screw
    • One 1.3 mm screw
  52. Этот шаг не переведен. Помогите перевести
    Remove the cellular antenna. Remove the cellular antenna.
    • Remove the cellular antenna.
  53. Этот шаг не переведен. Помогите перевести
    Remove the single 1.3 mm Phillips screw securing the antenna to the rear case.
    • Remove the single 1.3 mm Phillips screw securing the antenna to the rear case.
  54. Этот шаг не переведен. Помогите перевести
    Remove the Wi-Fi/Bluetooth antenna. Remove the Wi-Fi/Bluetooth antenna.
    • Remove the Wi-Fi/Bluetooth antenna.
Финишная черта
29 участников успешно повторили данное руководство.
Evan Noronha
Участник с: 05.02.2015
204 339 Репутация
Автор 178 руководств
Команда
iFixit Участник iFixit
Community
134 членов
Автор 14 951 руководств
Комментариев: 14
Omg
That was an intense read.
tedcmacdonald - Ответить
in iphone 6s 4.7" wifi antenna is the same and is in the same place?
Łukasz Gałęzewski - Ответить
Didn't you forget to mention first step to remove the two little screws by the power connector? First time doing this and I ended up breaking the metal threaded tabs that the screws go into :(
I guess I should have realized it would have screws somewhere and also researched some more before attempting the repair.
Oh well, looks like I will need to get some teflon tape or something to hold things together.
Patrick G - Ответить
Exactly! I also broke them, but fortunately I was also replacing the LCD Screen/Digitizer.
edgarjmiranda -
Hi, is this repair guide (and the antenna you sell) also valid for the non functioning bluetooth of an Iphone 6S ?
Basile Clot - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 122
За последние 30 дней: 520
За всё время: 68,674
