iPhone 7 Camera Cover Glass Replacement
Выберете то, что вам нужно
Видео обзор
iPhone 7 Camera Lens Glass Replacement
  1. iPhone 7 Camera Cover Glass Replacement, iPhone 7 camera lens glass replacement: шаг 1, изображение 1 из 2 iPhone 7 Camera Cover Glass Replacement, iPhone 7 camera lens glass replacement: шаг 1, изображение 2 из 2
    • Use a pair of tweezers to carefully remove the remains of any broken glass from the cracked camera cover.
    • While removing the broken glass, be very careful that the glass and your tweezers do not scratch the camera's lens. If the lens is scratched, it may prevent the camera from focusing properly.
    la colle B7000 convient parfaitement et garde l etancheité
    SAV E.LECLERC - Ответить
  2. iPhone 7 Camera Cover Glass Replacement: шаг 2, изображение 1 из 2 iPhone 7 Camera Cover Glass Replacement: шаг 2, изображение 2 из 2
    • Use a soft cloth to clean the camera's lens of small glass shards.
  3. iPhone 7 Camera Cover Glass Replacement: шаг 3, изображение 1 из 3 iPhone 7 Camera Cover Glass Replacement: шаг 3, изображение 2 из 3 iPhone 7 Camera Cover Glass Replacement: шаг 3, изображение 3 из 3
    • Unlock the phone and open the Camera app.
    • Test the camera by making sure that it focuses properly and there is no visible residue left on the lens.
    • If the rear-facing camera continues to have trouble focusing, continue carefully removing glass shards from the camera cover.
    • If you have removed all glass shards and the camera still does not focus properly, the lens may be scratched. Use the iPhone 7 Rear Camera replacement guide to replace the phone's rear-facing camera.
  4. iPhone 7 Camera Cover Glass Replacement: шаг 4, изображение 1 из 2 iPhone 7 Camera Cover Glass Replacement: шаг 4, изображение 2 из 2
    • Use a paperclip to remove the adhesive from around the camera's lens.
    • Use a soft cloth to remove any residue from the adhesive.
  5. iPhone 7 Camera Cover Glass Replacement: шаг 5, изображение 1 из 3 iPhone 7 Camera Cover Glass Replacement: шаг 5, изображение 2 из 3 iPhone 7 Camera Cover Glass Replacement: шаг 5, изображение 3 из 3
    • Install a new camera cover and attach it using silicone-based adhesive.
    • Make sure not to apply too much adhesive to the camera cover. If too much adhesive is applied, it may obstruct the camera's lens.
    • Press gently on the newly installed camera cover to securely attach the cover.
Заключение
After replacing the broken camera cover with a new one, open the phone’s Camera app. Check and make sure that the rear-facing camera is able to focus properly.
28 участников успешно повторили данное руководство.
Alex Sander
Участник с: 02/28/17
38 195 Репутация
Автор 202 руководств
8 Комментариев
does the glass come with glue already on it?
kolineal - Ответить
No, it does not come with the glue, you have to buy Silicone based adhesive so the phone can remain waterproof.
megaspeed -
The Video is showing how to replace the Glass.
Why do we need to buy this suggested part ‘ iPhone 7 Rear Camera Lens Cover’ (the whole Cover not just the Glass)?
Installing the whole cover needs a complete different Guide, including opening the iphone...
Simon Bonorand - Ответить
+1 agreed
this guide(link) is not at all helpful
Chris Farker -
Where is the link to buy replacement camera lens?
Erica McNulty - Ответить
I’m torn about this. On one hand, it’s not a complete repair in the sense that you can’t use the rear camera lens cover that is sold on iFixit but a “half-cover” that is easily purchased at different online venues, including Amazon (for which the guide provides a link).
In order to replace the actual OEM lens cover (iFixit part), you have to rip out the foam pad, camera alignment bracket, and lens cover. There is a terrible video of this on Youtube where the guy rips out the rear camera foam pads and alignment bracket while saying, “I have no idea what these do.”
In order to do this repair with the iFixit part, you need three parts (all sold on iFixit): the rear camera alignment bracket, the rear camera cover, and the rear camera foam pads. HOWEVER, since the original bracket is soldered (I think) to the cover, you would likely have to use adhesive to make the bracket stick unless you have very good soldering skills. Oh, and you have to open up the iPhone and take out the rear camera too.
Jim Shaw - Ответить
Best video instructions for "Replace Camera Lens of iPhone 7, 8 and SE2 (2020)": https://www.youtube.com/watch?v=Xg3mg8iA...
Pixel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 128
За последние 30 дней: 551
За всё время: 111,866
