Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
prereq only
Выберете то, что вам нужно
Use the flat end of a spudger to disconnect the rear-facing camera connector.
Remove the following Phillips screws securing the rear camera bracket to the rear case:
One 1.3 mm screw
One 2.5 mm screw
Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
Remove the Phillips screws securing the Wi-Fi antenna:
Three 1.2 mm screws
One 1.7 mm screw
