Введение
Folge den Schritten dieser Anleitung, um die Pentalobe Schrauben eines iPhone 7 zu entfernen oder auszutauschen.
Выберете то, что вам нужно
Schalte das iPhone aus, bevor du es zerlegst.
Entferne die zwei 3,4 mm Pentalobe Schrauben an der Unterkante des iPhones.
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
53 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
5 Комментариев
are there any water seals associated with the pentalobe screws? I blew compressed air into my iphone 7 and two tiny square rubber gaskets (~3mm) popped out. They squares have a round hole in them. I can only figure they are part of the pentalobe screw water seals, but I’m not sure, and I don’t know how to put them back in the phone to restore the water seal. Can anyone offer a solution?
@ataterka The screws themselves have a tiny ring-shaped rubber gasket on them. The two rubber squares you found slip onto the screw bosses. I don’t think those are needed for water sealing, and they’re not even included on newer models.
Does iPhone 7 and iPhone 8 (including «Plus» models) share the same bottom pentelope screws?
Put new lcd on with no problems then later batter went bad got new battery and can not get the 2 pentathlon screws out they loosen but not come out will tighten back up lossen but still want come out
How do I get screws out
